Go Back   Boat Design Forums > Design > Propulsion > Diesel Engines
Old 11-24-2006, 11:29 PM
darrenyorston darrenyorston is offline
Rep: 10 Posts: 9
Diesel Oil Pressure Query
I am new to diesel engines and have a query about the oil pressure. I have a VDO oil pressure gauge on my bridge and whilst the engine is running the need constantly flickers between 25-75kpa. Given the gauge only goes from 0-100kpa I don't find it really helpfull. Is there something wrong with my gauge or the sender? The oile pressure gauge I have on my petrol car does not do this.
Appreciate an advice or suggestions.
Old 11-25-2006, 05:19 AM
Rep: 700 Posts: 3,208
bad grounds.
FAST FRED
Old 11-25-2006, 05:29 AM
Rep: 10 Posts: 9
How do I go about fixing it?
Old 11-25-2006, 08:39 PM
Frosty's Avatar
Frosty Frosty is offline
Rep: 1528 Posts: 5,518
At a guess, I would say that this problem is only when it warms up and has been running for a while? If you put the wire off the sender to the block the guage should read max, if it does then its the sender at fault. Checking grounds wouldnt hurt.
Faulty oil pressure senders is common, and no cars dont suffer as much, probably because the cars RPM is constantly changing--along with oil pressure.
Steel Welding query JimCooper Metal Boat Building 23 08-13-2009 03:46 AM
NEW affordable, long-term liveaboard design query Filmdaddy Projects & Proposals 37 04-30-2006 09:33 PM
hamilton jet query kevsabout Propulsion 14 06-01-2005 04:29 AM
Engine query olley8 Powerboats 4 01-15-2005 06:29 AM
Pressure test RDB Metal Boat Building 6 08-12-2004 11:30 AM
