Go Back   Boat Design Forums > Design > Propulsion > Diesel Engines
  #31
Old 04-03-2006, 08:27 AM
fredrosse's Avatar
fredrosse fredrosse is offline
USACE Steam
Rep: 29 Posts: 55
Torque & Horsepower
The fundamental relationship between Torque and Horsepower is as follows:
HP (USA STANDARD) = Torque (Ft-LBf) x RPM x ( 2 x 3.14159 / 33,000 )
Where :
HP = USA STANDARD = James Watt Standard = 33,000 Ft-LBf / min
Torque = (Ft-LBf)
RPM = Revolutions per minute
Rearranging for conveinence:
HP (USA STANDARD) = Torque (Ft-LBf) x RPM / 5252
Torque (Ft-LBf) = 5252 x HP (USA STANDARD) / RPM
Reduction gears change the RPM output, and the output torque, horsepower remains essentially constant, except for some small loss (nominally 1 to 3%) across each gear reduction.
If you can give further details as to the boat displacement, hull type, waterline length, and desired speed, the proper propeller diameter and pitch can be selected. Depending on the availability to mount the ideal prop, some compromise is ususlly met, adjusting prop size and pitch to fit the constraints of the hull.
  #32
Old 04-10-2006, 08:27 PM
Rep: 1493 Posts: 7,447
40 HP is 40 HP regardless of brand. The RPMs at which the power is rated will indicate what the torque is. However, with a higher revving engine and a higher ratio reduction, it is possible to turn the same wheel. There is no difference.
  #33
Old 04-17-2006, 04:36 PM
Rep: 756 Posts: 3,328
"We will still only inject 10 mm3 thus the btu content for the 10 mm3 @ 35C° will be lower. Lower btu per injection event = less power."
Even the lowly mechanical govenor on a Detriot 2 stroke will compensate for thin hot fuel.
The rack simply calls for MORE FUEL to keep the rpm the same , weather the load changes or the fuel does.
They were no dummies in 1936!
FAST FRED
  #34
Old 04-18-2006, 07:50 AM
Karl2 Karl2 is offline
Rep: 34 Posts: 67
Fred,
Yes - And all mechanical engines with a governor will do the same. BUT only at partial load. At full load (and this is where your power loss due to fuel temp is noticable) the mechanical governor can do nothing to compensate.
Karl2
  #35
Old 04-18-2006, 11:54 AM
Thunderhead19 Thunderhead19 is offline
Rep: 21 Posts: 504
The standard for measuring engine horsepower output is "Brake" horsepower (which, as Gonzo describes is measured by torque at RPM acting on a water brake). I have, however, seen horespower published in terms of "shaft" horsepower, and in another way that I can't quite recall (Similar to Drawbar horsepower).
I have had diesel engines Dyno tested, and actually have never seen one fail to meet the publilshed values. I have heard of them though.
One interesting point is that some manufacturers will sell the same engine as a commercial engine and as a recreational engine. The commercial engine has a lower reccommended continuous operating RPM and therefore a lower Max Horsepower rating. (But it's the same engine)
JDF
'"Forward, the Light Brigade!"'
-Alfred Lord Tennyson
Solomon Technologies - "Electric Wheel" electric motor propulsion systems lockhughes Hybrid 228 10-12-2011 04:00 PM
Auto engine marinization DIY Marinizing 231 07-01-2010 07:34 PM
Finally cheap, low HP diesel engine! mattotoole Propulsion 1 06-14-2005 09:36 PM
Looking for used 300 hp diesel for 30' cape islander (converting to a fast picnic bt) rbeck Marketplace 0 09-02-2004 04:27 PM
Diesel Engine Efficiency winap Boat Design 7 07-11-2004 03:06 AM
