Go Back   Boat Design Forums > Design > Propulsion > Diesel Engines
Old 03-11-2007, 07:46 PM
johnW johnW is offline
Rep: 10 Posts: 8
Diesel fuel return line
A friend's new (to him) boat has the diesel return line connected to the feed line before his first filter. I always thought the return line should go back to the tank(s). Has anyone else piped the return into the engine feed line? Your experience would be appreciated as this would simplify the installation of my Yanmar. My friend's boat has an older 3 cylinder Volvo.
Old 03-11-2007, 11:49 PM
Frosty's Avatar
Frosty Frosty is online now
Rep: 1528 Posts: 5,518
Theres 2 types of returns.
One is a serious amount of fuel and has to return to the tank. Maybe as much as 30 % returns that way.
The type your friend must have is called basically a leak off return. This a tiny amount and is just what leaks by injectors and pump.
This can and is normally connected back to the filter.
My Yanmars even have a fuel cooler before returning to tank.
This return system where substantial ammounts return to the tank also has the benefit of filtering fuel constantly when on the go.
Old 03-12-2007, 07:32 PM
bilgeboy bilgeboy is offline
Rep: 45 Posts: 157
I didn't know this other style existed, Jack.
I think if you are installing a new Yanmar, you would want to return it to the tank, at least to have cooler fuel and the constant "polishing" effect Jack mentioned. I don't see this as complicating the massive project you are working on at all. The diesel pick-up and return is the same, doesn't matter how you hook 'em up (at least on my brand new tank). The hose is not very expensive and very flexible.
Congrats on the new motor!
Mike
Old 03-12-2007, 10:51 PM
Frosty's Avatar
The leak off type is a very small amout I had one once on a big Mitsubushi and I just put the pipe into a plastic bottle . It took weeks to fill it.
The return should not go to the filter,--I tried it on an initial engine installation, for reasons I can quite fathon out the engine would only run at slow speed. Trying to rev up stopped it.
Quickly laying in some returns cured the problem imediately.
Old 03-13-2007, 05:51 PM
Rep: 10 Posts: 8
Thanks for your advise guys, it was appreciated. This arrangement did not seem like a good system to me but as I have 3 tanks, it would have simplified my installation.
Old 03-14-2007, 08:00 AM
kenJ kenJ is offline
Rep: 56 Posts: 323
3 tanks
If one of your tanks is considered the feed tank, just route the return to it. In any case I don't think you need to return to all 3 tanks. I don't think the amount of fuel we are bypassing will amount to much, and if it is, you know which tank is getting the partial refill.
Old 03-14-2007, 10:17 AM
Eric Sponberg's Avatar
Rep: 2464 Posts: 1,381
On the little MD2 two-cylinder Volvo diesel that I had in my 27' sailboat, there was a feed pump with a strainer ahead of it, and between the pump and the injectors was a fuel filter--a large bowl with a paper filter in it. The return line went back to the inlet into this fuel filter. Worked fine on such a small engine.
On the Moloka'i Strait motoryachts and other large engine installations, we have a day tank that feeds the engines, and any of a number of storage tanks. The return line is usually plumbed to one of the storage tanks, preferrably at the farthest end forward so that the return fuel has a good opportunity to cool before being needed again. If you return to the day tank, the day tank fuel will heat up eventually, particularly if you are on a long voyage.
Eric
Eric W. Sponberg
Naval Architect
Sponberg Yacht Design Inc.
St. Augustine, Florida
www.sponbergyachtdesign.com
fuel tank_fuel line huds_n Boatbuilding 6 11-16-2006 12:01 AM
Intergral diesel fuel tank pescaloco Boat Design 8 10-14-2006 10:31 AM
return of sails in era of expensive oil, enviro. regs? eskribage Boat Design 15 11-30-2005 08:06 PM
mold insert to deal with negative return corners?? Pavook Fiberglass and Composite Boat Building 4 11-28-2005 01:10 PM
Diesel Fuel consumption gcampbell Diesel Engines 5 11-28-2005 06:41 AM
