Go Back   Boat Design Forums > Design > Propulsion > Diesel Engines
Old 11-26-2005, 02:54 PM
gcampbell gcampbell is offline
Rep: 10 Posts: 3
Diesel Fuel consumption
Gentlemen: I have heard a rumor that long range offshore fishermen (maybe commercial) in the northeast US are using an odd drive configuration with IB diesel power and extra large props. Any info on the subject? Somehow they are getting great fuel milage. Thanks in advance.
Old 11-26-2005, 02:57 PM
marshmat's Avatar
marshmat marshmat is offline
Rep: 1918 Posts: 4,113
IB diesel power and huge props would indeed imply very good fuel efficiency. I haven't seen the system you seem to be talking about though, I'll see what I can find.
Old 11-26-2005, 05:56 PM
Rep: 10 Posts: 3
More info
Thanks for the reply Marshmat. I believe the basic idea is to use 3:1 or 4:1 transmissions and larger props with a lot of bite.... general parameters show 40ft boats gaining 7-8 kts and showing a small decrease in fuel consumption
Old 11-27-2005, 02:07 PM
Deering Deering is offline
Rep: 14 Posts: 219
Bigger props are almost always more efficient, but usually limited by clearance space between prop shaft and hull. How are they getting around that limitation?
Old 11-27-2005, 10:38 PM
Rep: 10 Posts: 3
Thanks for the reply Deerling, I dont have that info.... its all part of the info I am looking for. For myself, I will form a concave section into the hull if I need to.... but that is a much larger discussion for a later day. GC
Old 11-28-2005, 06:41 AM
Rep: 700 Posts: 3,208
Simplest method of reducing fuel consumption is to use a prop with fewer blades. As long as the blade area were enough , and the diameter wouldnt cause grounding problems a 2 blade would be best.
There were single blade props made for aircraft , but the dia would be huge for a boat.
FAST FRED
Monohull verses Multihull powersailers / motorsailers brian eiland Motorsailers 257 12-14-2011 12:10 AM
Twin V6 to single diesel conversion burt2 Propulsion 21 02-01-2011 08:00 PM
Fuel consumption? duluthboats Boat Design 7 01-06-2006 06:07 AM
Fuel Cell Technology - It's on the way... caribmon Boatbuilding 0 11-15-2005 05:11 AM
Fuel consumption of 43' Cruiser salimbag Powerboats 5 01-27-2005 11:20 PM
