Go Back   Boat Design Forums > Design > Propulsion > Diesel Engines
Old 02-28-2006, 01:59 PM
pcn pcn is offline
Diesel Boxer
Has anyone encountered a diesel engine (marine or otherwise) in a "boxer" configuration - or is there some showstopper unique to diesel combustion that disqualifies this option?
Old 04-06-2006, 08:12 PM
moTthediesel moTthediesel is offline
Rep: 18 Posts: 71
Well, there are the Fairbanks-Morse horizontal opposed piston engines.
They could truely be called "boxers" as their pistons could be seen as punching at each other
For something really wild, check out the Napier Deltic engine, with three banks of opposed piston cylinders arranged in a delta shape, with three crankshafts geared together to the transmission.
There'll always be an England
moT
Old 04-07-2006, 04:28 AM
antonfourie antonfourie is offline
Rep: 13 Posts: 169
The English do like their strange engines, like the rotary engine from WWI where the crankshaft was attached to the aircraft, and the prop was attached to the cylinders which spun around the crankshaft.
Old 04-07-2006, 09:24 AM
Rep: 18 Posts: 71
It wasn't only the English that used rotary aircraft engines in WW1, the French Gnome et Rhone engine was used in many of their aircraft as well.
There was no way to throttle those engines, so they ran "wide open" all the time. They were controled by switching the ignitions off and on, that accounts for the strange "burst of revs" sound you hear as they land.
moT
Old 05-03-2006, 03:42 AM
StianM's Avatar
StianM StianM is offline
Rep: 114 Posts: 577
I belive the Danish Callesen or something like that made diesel boxers for ferrys. This was done to get them fitted under the low deck's
Maybe it was a other? I'm shure it was danish
Old 05-05-2006, 02:59 AM
StianM's Avatar
Rep: 114 Posts: 577
moT
The engine to the right is a Napier Nomad. It's the same construction, but the Nomad is a compound engine, It's developed during the 50's, but stil hold the record as the moust fuel efficiant aircraft engine ever buildt. There was fuel injection to the compund so that power could be increased during take off
Old 05-05-2006, 09:15 AM
Rep: 18 Posts: 71
Dats watt I'm talkin' bowt
Thanks for posting that animation, v. cool
moT
Old 05-05-2006, 12:10 PM
StianM's Avatar
Rep: 114 Posts: 577
You have ti be sick to make a engine like this and mentaly ill not to like it.
I'm still wondering if it was callesen or not the produced those ferry boat boxers.
Old 09-05-2006, 05:33 PM
waqas20 waqas20 is offline
Rep: 10 Posts: 3
Yes there is a diesel (jet a fuel) called diesel air but I think they could be used in the marine world. Diesel air did try
Old 09-06-2006, 06:22 AM
Rep: 700 Posts: 3,208
"There was fuel injection to the compund so that power could be increased during take off"
Are you sure ?
Usually the old recips were water or water alcohol injected to allow higher (5 min limit) take off power.
Our 3350 3 row recips would pull 54 inches of manifold pressure at 2900 with the water on.
Only 48 inches MAP without the water
Pair was mounted on Neptune P2V7,s.
FAST FRED
Old 09-07-2006, 12:51 AM
StianM's Avatar
Rep: 114 Posts: 577
Water and alcohol was injected to the air intake for combustion.
Here the fuel is injected betwen the engine and the compund turbine and is burned in the extra okygen you find in a diesel engine.
Diesel/Electric vs. Diesel/Hydraulic? GumbyTheBorg Hybrid 7 06-27-2006 10:11 AM
best sterndrive for diesel brianhayes1 Open Discussion: All Things Boats & Boating 0 11-12-2005 10:27 AM
HELP Diesel or not brianhayes1 Propulsion 3 09-29-2005 08:57 AM
Diesel Electric Again DiverDown Propulsion 9 04-12-2005 10:13 PM
Mercedies diesel F S ted655 Marketplace 7 04-09-2005 08:58 PM
