Go Back   Boat Design Forums > Design > Propulsion > Diesel Engines
Old 09-13-2009, 07:56 PM
singleprop singleprop is offline
Rep: 10 Posts: 48
correct loading of engine using CPP
LWL 49', full displacement, troller type hull.
4 bladed 850mm controllable pitch propeller.
Hydraulic stabilizers, anchor, air conditioning powered by the main engine, emergency sail plan (or can be used as "motorsailer").
Projected power requirements CALM CONDITIONS at DWL (67,515 lb) and at 2” loading (73,144 lb) :
V/L ... Knots ... HP at DWL ... HP at 2” loading
1 .......... 6.84 ...........12.3 ................13.3
1.1 ...... 7.53 ........... 18.9 ................ 20.5
1.15 .... 7.87 ........... 23.2 ................ 25.1
1.2 ...... 8.21 ........... 30.1 ................ 32.6
1.25 .... 8.55 ........... 40.3 ................ 43.6
1.3 ...... 8.9 ............. 54.6 ................ 59.2
1.35 ... 9.24 ............ 74.2 ................ 80.4
The engine is a Deutz BF6M1013MC (same as the Volvo D7A-TA).
Engine Volvo D7A-TA , 177 HP @ 1900 RPM, see data on http://vppneuapps.volvo.com/ww/PIE/ViewFileFrame.aspx?n=189947&r=2009-02-09-16-00-17&t=PDF1P&a=7748598&p=T416&d=Product[/url] Bulletins&s=236392&id=2533&lang=en-GB
or
http://www.deutz.de/live_deutz_produ...013m_us-en.pdf
Will it be possible to load this engine correctly at V/L speed using the CPP in calm conditions?
Does anyone have data on how much power requirements increase with increase in seastate, i.e if going from calm conditions at 1.1 V/L to 1.1 V/L in seastate 6, how much extra HP is needed?
Regards Singleprop
1953 Correct Craft racer with 327 Fireball Engine Tangusso Boat Design 0 09-04-2008 07:07 AM
1953 Correct Craft Racer w/327 fireball engine Tangusso Materials 0 09-04-2008 07:05 AM
Correct stern drive for Volvo engine cnoel1 Sterndrives 1 05-04-2006 09:45 AM
Engine loading operator Boat Design 8 04-25-2005 06:07 PM
Propeller sizing and engine loading E4ODnut Props 3 12-29-2004 05:50 PM
