| Cleaning Heat Exchangers- Greetings,The age old debate,out here in the jungle,What to use for cleaning Heat Exchangers? Muriatic Acid? Vinegar? What works well and fast? ![]() |
| I think muriatic acid is the DIY standard. I glued up some PVC cylinders and end caps to accomodate the diameter of my bundles, soaked 1/2 hour in the bath tub, standing on end. Not sure of strength/molarity/molality...whatever you want to call it...just off-the-shelf Home Depot strength. Make sure the wife and kids aren't home...thats a "note-to-self" moment. I really stunk up the house and the fumes are deadly. Best done outside! This is not a brain surgery procedure, but vinegar will take forever, don't shy away from good ol' fashioned HCl. Mike |
| Do yourself a favor and take them to a radiator shop and have them boiled. They'll come out much cleaner then what you can do with hardware store chemistry. |
| Jungle fixes Good Morning, Out here in the wild,there is no Rad shop or Home Depot. But I have been using a 3-1 H2O/HCI mix for 30 min and it seems to work well. Anymore Ideas or suggestions. Some folks really frown when they hear about HCI... ![]() |
| Acid as you described works for removing mineral scale. Any fouling from biological/organic sources will respond to warm caustic soda solution(chemical name: sodium hydroxide NAOH, also known as lye). You can use test strips from a pool chemical supply house to measure the pH of your solution. Add enough acid to water to lower the pH to between 2 and 2.5. The pH level will tell you when the solution is strong enough. Caustic sods is the opposite of acid, it is basic. Add caustic powder to water until the mixture has a pH of 12; that will be strong enough to dissolve any organic fouling. Treating with one, then with the other should get everything out. Be very sure to use rubber gloves and, most importantly, eye protection. Be sure to add a little acid or caustic at a time to a container of water. Never add water to acid or caustic. It will boil and foam violently.
__________________ Best, Charlie Last edited by charmc : 02-24-2008 at 11:03 PM. Reason: Important precaution |
| BTW, muriatic acid and hydrochloric acid are the same thing. Muriatic is a traditional name.
__________________ Best, Charlie |
| Exchangers Thank you Charlie for the detailed explanation.I'll see whats available out here in a 'developing' area of Panama,lye should be available,I'll just have to work on the right mixture. JD |
| What about tile cleaner from the supermarket. You got a little supermarket aint ya? You say you are in the jungle so what do you mean heat exchanger? water to water or a radiator? |
| heat exchanger cleaning | kenJ | Diesel Engines | 2 | 12-15-2006 11:04 AM |
| heat exchanging radiator | mattoc | Boat Design | 10 | 07-04-2006 11:48 AM |
| Propane or Diesel Heat? | KevinT | Metal Boat Building | 28 | 02-08-2006 02:26 PM |
| Cabin Heat From an Outboard | CaptPPan | Powerboats | 5 | 06-23-2005 10:08 PM |
| Heat insulating fabric help | Archea47 | Materials | 7 | 05-11-2005 02:09 AM |
