| I know you said that your not overheating but did you pull that raw water line and check for full flow? ![]() |
| I guess you mean the line that exits the bottom of the heat exchange. - Yep - besides its a new exchanger. I mean at 3800 rpm you have got a lot of exhaust velocity going on. Ill keep a watch on it. Frosty - yes back pressure is important - same muffler since 86 I guess. How would I know if it the right size? |
| If the water going to the exhaust elbow is too hot to touch (over 140F) it is plugging the heat exchanger and other areas with salt from the heat. FF |
| The burnt rubber smell might be a gasket getting roasted |
| Out sunday for a long run - not so bad now - I expect the time I had blockage and it got so hot - seems even less - Max rpm stayed cool enough - manifold was hot, hot to touch. No burny. dealing with the prop pitch - rpm issues. |
| Diesel Smell | Brent Swain | Boat Design | 0 | 02-13-2008 03:43 PM |
| Burnt Points | FISHERMAN1 | Electrical Systems | 8 | 06-04-2007 07:13 AM |
| rubber coupling angle | JamesN | Jet Drives | 3 | 05-06-2007 06:22 AM |
| polyurethane rubber | Materials | 1 | 06-29-2002 09:20 PM | |
