Go Back   Boat Design Forums > Design > Propulsion > Diesel Engines
Old 06-29-2009, 10:50 PM
Rep: 472 Posts: 1,391
Building Raw water filter with PVC pipe
I need to two large flow water filters. I am not happy with typical bronze and glass units. They are expensive, corrode and other wise seem primitive.
I have built rain water collection from pvc pipes and it looks like I could scale it up for raw water use.
Advantage relatively cheap
No Corrosion
Horizontal mounting
Multiple filtration possible.
Disadvantage, no glass
Easy cleanout, just remove screw in plug
Horizontal mounting
What do you guys think?
Old 06-29-2009, 11:04 PM
masalai masalai is offline
masalai
Rep: 1630 Posts: 7,322
I assume the flow is lo velocity allowing the heavy sediment to naturally fall into the "Cleanout" section, and that there is no light undesirable stuff mixed in that raw water that would not settle down very quickly before flowing on to the "raw water out" end - in which case - looks good to me...
My concern is with lighter contaminants like Irukandji (Carukua barnesi) a very tiny and very poisonous jellyfish found in Nth Queensland waters when SE trades blow them onto the beaches, or shallows... I do not want that sucked into my raw water intake - particularly the R.O. 'watermaker' system...
Try to be helpful... The trouble with people is to realise and remember that there are at least two sides for every story...
A woman's breasts, one is not enough, - two may be just right, - but dreaming of 3 is a pleasant fantasy...
Old 06-30-2009, 12:23 AM
Manie B's Avatar
Manie B Manie B is offline
Rep: 1391 Posts: 1,539
sorry but water filtration is way more complicated than that
Bye bye Folks - off to see the world ~~~/)~~~ :)
Compulsive Neurotic Manic Depressive,
but basically happy :)
http://compaxboats.wordpress.com/
http://www.boatdesign.net/forums/boa...ser-27869.html
Old 06-30-2009, 12:42 AM
masalai
depends what is to be removed - I assumed a small amount of largish sand grains for his for mine ? - I do not want to touch the jelly fish bits as they can still sting?
Old 06-30-2009, 03:25 PM
Rep: 1397 Posts: 7,216
Algae and sea grass are usually one of the worst culprits for clogging
Old 06-30-2009, 07:08 PM
No you guys don't see the multiple screens inside pipe.
Old 06-30-2009, 07:21 PM
masalai
hehehe
Old 07-01-2009, 12:13 AM
Take a look at this link: http://www.fluidtrol.com/wye_strainer.htm
Old 07-28-2009, 10:20 PM
Garry265 Garry265 is offline
Rep: 10 Posts: 2
mydauphin
Hi could you please email me at garry@picknowl.com.au
would like to ask you about prior post Thanks
Old 11-24-2010, 05:44 AM
anthony goodson anthony goodson is offline
Rep: 241 Posts: 391
I know this is an old post revived ,but I must have missed it. The item shown in the original post is available in Spain from any outlet selling agricultural irrigation equipment. They are available in several sizes ,the last time I looked the 1" bore size was about 8 or 9 euros .They are made of a very tough plastic ,possibly glass filled nylon or similar. and most contain a fine mesh filter. As well as working on the suction side of a pump they will also work on the pressure side of a jet. I have never known one leak or fail .
Building a raft w/ pvc pipe? Aberamonli Boatbuilding 31 01-08-2012 11:23 AM
4 inch pvc pipe raft. rickjames Boat Design 17 07-13-2009 12:40 PM
PVC Pipe Canoe camping nut Boatbuilding 19 09-22-2008 01:42 PM
fiberglassing PVC pipe?? georgiahemi Boat Design 5 10-05-2007 07:05 AM
150mm pvc pipe jgfish Materials 17 01-23-2007 09:16 AM
