Go Back   Boat Design Forums > Design > Propulsion > Diesel Engines
Old 12-19-2006, 10:22 PM
DAVID HOSEGOOD DAVID HOSEGOOD is offline
DAVE H
Rep: 10 Posts: 2
Borg Warner Velvet Drive Model 72c Current Model
Hi all iam new to this forum actually new to any forum
I have a small problem with a project which involves my velvet drive
What iam trying to do is this I have a small 3 kilowat 3 phase electric motor
one KEB electric drive control and one of two two generators on board plus one ups with one weeks back up storage Yes thats battery backup weigths 1.5 tons
I am trying to install this electric motor so that when in port and i want move the boats a short distance I can use an electric motor my idea is to connect electric motor through a set of gears ie chain and sprocket to propeller shaft that comes out of gear box
Main problem I live in New Zealand and we dont have anyone around who i can ask about the gear box side, as to when electric motor is running will it do damage to gear box as the tail shaft is going to be turning but the main diesel engine and gear box is going to be in neutral.
The electric drive and the motor is no problem or ups ie motor is three phase
My ocupation is an electronics tec for vectek electronics we build shorepower systems for superyachts.
This motor is not reaqlly intended as a replacement for my main means
of propulsion only for in harbour or manuvering.
All comments would be gratefully recieved
Dave h
Old 12-27-2006, 12:30 AM
Rep: 712 Posts: 4,555
It would be cheaper to install an electric drive with tilt. The gears will overheat if you run them without the engine. The oil pump lubricates and cools the system. Also the heat exchanger cools the oil.
Borg/Velvet questions mainstreetmark Inboards 13 04-14-2007 06:31 AM
Borg-Warner Vee Drive? RHough Sailboats 2 09-29-2006 07:12 PM
Velvet Drive DOGGYDOO Propulsion 4 01-07-2006 04:18 PM
Velvet Drive 72C/ Mercruiser 6.2? drs3317 Propulsion 1 11-12-2005 12:06 AM
Velvet-Drive 71 (10-17) gonzo Propulsion 8 06-04-2005 06:08 PM
