| banks power kit i just put a banks power kit into my ford f350 6.0 litre turbo diesel. good description of the system at http://www.bankspower.com/ and i'm highly satisfied with the result. does anyone know of comparable retrofit for diesl engines in boats? have not talked with banks about this yet but i don't see anything on the site for boats per se. |
| The only difference should be the headers witch nead to be water cooled. This would reduce the amount of power the turbo could extract from the exhaust gas. |
| In a truck or RV the ability to use gross amounts of power is limited to the sixe of the hill, and the vehicle load. On a vessel the ability to accept high HP is constant , and the service life of the engine may be hugely shortened. Think of an engine as a defuller , take 5gph (100hp)from a large tank and it will take a long time to run thru 10,000G. Take 50 gph and the engine is scrap in less than 1/10 the time , if its strong enough to survive at 50gph.. FF |
turned the banks up to level six last night to see what she'd do under stress. gunned it straight up a very steep hill. about half-way up the turbo decompressed rapidly. thought it blew the thermostat out the manifold, i tapped it only 3-1/2 turns which i thought might be light but turns out it throug the air intake right off the turbo. that's a lot of pressure. tightened her down this morning and all appears well again, and in context with your comments i don't know what i was thinking with that kind of power on a screw. burning fuel making bubbles. jet maybe, who knows, but excellent point. thanks again. |
| Continuity problem between banks | DonB | Electrical Systems | 4 | 10-17-2008 01:43 PM |
| How To Mount Small Outboard On The Grand Banks Wooden Dory | doryman | Wooden Boat Building and Restoration | 3 | 04-25-2008 11:18 PM |
| Grand banks 32 | fcfc | Boat Design | 1 | 03-31-2005 01:38 AM |
| Grand Banks 32 | Josh | Open Discussion: All Things Boats & Boating | 6 | 12-12-2004 08:09 PM |
| Searching the Memory Banks | kudu | Boat Design | 3 | 07-30-2003 12:03 PM |
