Go Back   Boat Design Forums > Design > Propulsion > Diesel Engines
Old 07-12-2006, 04:55 AM
Rep: 756 Posts: 3,328
Any Pancake engines made?
Some time ago the "pancake" engines were common in some industrial & marine applications.
Usually just a std engine laid on its side with the necessary mods to lube properly , and be serviced from only one side.
Am contemplating the use of such an engine due to its lower hight.
Are there any still being made? 100 to 200hp class.
FAST FRED
Old 07-12-2006, 05:13 AM
Frosty's Avatar
Frosty Frosty is online now
Rep: 1693 Posts: 5,865
Never heard of em bieng called a pancake engine but yanmar industrial make small ones up to about 20HP. Noisy little devils but made to go on and on in some field some where connected to a 50 gallon drum of fuel and a 50 gallon drum of water. But as you say they are accessable from the rear and side. I used to have one on a generator, you could remove the big end bearings with out removing the oil. The cylinder liner was pushed home with the head bolts, and the crank came out of one side with ball bearings on both ends.
A complete overhaul( exept a crank grind) could be done in the field in say,Oh 3 hours max
Old 07-15-2006, 04:42 AM
Redsky Redsky is offline
Rep: 9 Posts: 107
well i dont exactly recall the make cummins maby but a pancake desil was used on all the old stainless side greyhound buss's..along with a HD automatic trans...some older ones were manuel also as i recall.
Old 07-22-2006, 05:22 PM
george allard george allard is offline
Rep: 7 Posts: 61
The only "pancake" engines, that I have seen latley, Are Continentals, 12 cylinder, in USA tanks.
Old 08-04-2006, 10:43 AM
Swimpy Swimpy is offline
Rep: 10 Posts: 11
Just saw a Detroit 6-71 Pancake on EBay.
Swimpy
Old 10-27-2006, 05:07 PM
ron17571 ron17571 is offline
Rep: 10 Posts: 74
Fred u ever find that pancake motor?i read abot them being used in asia,i heard emissions problems keep them outa the usa.
Old 12-16-2006, 12:33 AM
moTthediesel moTthediesel is offline
Rep: 18 Posts: 71
To revive this thread:
Was just reading that Subaru will be introducing a boxer 4 diesel into the Euro market next year, than (maybe) US soon after.
Direct injection, common rail type, not sure of the output, but surely over 100 hp I would think.
A marinized version would be sweet fer shur
moT
Old 12-16-2006, 04:08 AM
Subaru has good reputation , a load of small aircraft fly with them , and flying , like boating requires constant power.
The only, not too hard to find pancake , or laid on its side engine, I have found ,so far is the DD 4-53 in its marine version, about 1960 era.
There still about 1000 lbs for 120hp , and only produce 16 hp from a gal of fuel as the design is 1930's.
A light weight diesel without a belt cam drive and with mechanical injection still is on the shopping list.
FF
Old 12-16-2006, 01:21 PM
Rep: 18 Posts: 71
FF
This engine will be light, I'm sure, and as I understand it, it will have chain driven cams. Alas, I'm afraid the mechanical injection diesel car engine has gone the way of the Dodo.
moT
Old 12-17-2006, 04:24 AM
"Alas, I'm afraid the mechanical injection diesel car engine has gone the way of the Dodo."
Probably , but there is always the industrial and truck stuff as a source.
By finding a good engine and using the LAST configuration before the electric version , much of the modern engineering should be avilable.
Need about 150hp as a max with 50 to 120 for the cruise regime, hopefully not at 1200lbs.
FF
Home made raft Matt Haines Open Discussion: All Things Boats & Boating 1 03-28-2007 04:15 PM
plug made.. mold made.. now what mungral Fiberglass and Composite Boat Building 16 01-14-2006 09:24 PM
Getting plugs and molds made C-Salt Boat Molds 7 12-17-2005 02:15 PM
Whats the best yacht ever made?? Peter H Boat Design 21 08-22-2005 02:38 PM
Need a Mold Made Bob Hostetter Marketplace 6 07-14-2005 10:00 AM
