| Air Filter needed for pathfinder diesal Regarding the Volkswagen Pathfinder Diesal; Does anyone know where I can get an air filter for this engine. Mine is the 50hp pathfinder. I am in So. California. Thanks, Kelldog. |
| You mean Nissan Pathfinder, right? |
| Not Nissan. Sorry, should have been more precise. It is a Volkswagon Pathfinder Diesel 50hp. |
| What kind of installation is it? Depending on the headroom, they are different options.
__________________ Gonzo |
If it is this engine type then the specs of a non marinised version in a car are as follow: For example a 1978 Volkswagen Golf L Diesel http://www.carfolio.com/specificatio...car/?car=43032 - Bore × stroke: 76.50 mm × 80.00 mm, 3.01 in × 3.15 in - Cylinders: Straight 4 - Displacement: 1.5 litre, 1471 cc, (89.766 cu in) - Type: Single OverHead Camshaft, 2 valves per cylinder, 8 valves in total - Compression ratio: 23.50:1 - Fuel system: Bosch diesel inj. - Maximum power: (DIN) 50.7 HP/PS/PK/CV/etc. (50.0 bhp) (37.3 kW) @ 5000 rpm - Specific output: 34 bhp/litre, 0.56 bhp/cu in - Maximum torque: (DIN) 80.0 Nm (59 ft·lb) (8.2 kgm) @ 3000 rpm - bmep = Brake Mean Effective Pressure: 683.4 kPa (99.1 psi) - Specific torque: 54.38 Nm/litre - Maximum rpm: ???? - Main bearings: 5 - Coolant: Water - Bore/stroke ratio: 0.96 - Unitary capacity: 367.75 cc/cylinder - Aspiration: Normal D. (atmospheric pressure) - Compressor: None - Intercooler: None - Catalytic converter: None To come back to the air filter question; on this forum was told to me, here in post#16 and here in post#20, ‘‘no air filter on a marine diesel’’. Good Luck! Angel |
| Most small diesels I have seen have a silencer on the intake. Looks very similiar to an air filter, but the function is to reduce intake noise, not filter the air. some are paper, some are metal mesh affairs. I have even seen K&N car air filters used. Just about anything will work or if the box is well sound insulated, use nothing. |
| Building Raw water filter with PVC pipe | mydauphin | Diesel Engines | 9 | 11-24-2010 04:44 AM |
| Need help finding a oil filter relocation kit. | bntii | Diesel Engines | 17 | 08-25-2009 11:03 PM |
| the best fuel filter for gasoline engines | naturewaterboy | Gas Engines | 26 | 08-10-2009 02:50 PM |
| "HRV" Air to Air exchanger for ventilation? | ldrumond | Boat Design | 5 | 12-09-2006 08:51 PM |
| Need Assistance from HP Filter Experts... | d_assassin | Sailboats | 2 | 08-04-2006 03:29 PM |
