| Advice on a engine Hello I have found a couple of engines and I hope some of you can tell me if they are good designs. One is a Detroit/Volvo Tamb73p 430hp with less than 400 hours. I will need to find more info. Next is a 671TI 485hp with a MG507A 1.5;1 again I will need to get more info. Thanks for your help |
| With the ratings provided I would assume both these engines are from a high speed sport fish. IF that is what you need , great , but if its for a boat that onlt will be using 100 or 200 hp, a better choice could be made. Either of these engines will be really hard pressed to run 1000hours as sport fish engines. This is NORMAL, and accepted for high performance. FF |
| Vetus electronic engine remote controll, and setting starbord engine do conter clockw | omnitrips.com | OnBoard Electronics & Controls | 11 | 06-21-2009 01:43 AM |
| From a V-? engine to a 4 cyl.... building the front engine pad | sikpupy | Fiberglass and Composite Boat Building | 0 | 06-10-2008 08:39 PM |
| 140 mercruser engine c.i.d. identificafion by engine serial number | ggsimpson | Gas Engines | 0 | 11-18-2006 10:39 AM |
| Need Advice on engine height | Arrowmarine | Boatbuilding | 5 | 11-10-2004 08:21 PM |
| Replacing an outboard engine with an inboard engine | boere | Boatbuilding | 0 | 06-23-2003 04:21 AM |
