| Advice on Cummins 555s Hi I am new to this forum. I am about to purchase a 38 ft Riveria with twin 555 Cummins engines with about 1700 hours.The price is attractive enough to repower if needed. What special items should I check for on pre purchase inspection of these engines? Is their seemingly poor reputation justified? Any advice would be appreciated. Last edited by lunar9 : 03-23-2007 at 07:50 PM. Reason: no title |
| Get an engine surveyor, he will be worth his weight in gold. All the necessary tests should be done such as compression test, oil samples, boost check, coolant samples, EGT test, tranny oil samples, tranny output test and a full sea trial. |
| Cummins 555m advice Thanks for your reply. My experience is limited to Perkins & Volvo marine diesels. I am unsure if the negative "forum speak" surrounding the 555's is fully justified. regards |
| Funny thing.... as with everything in this world, if one in a thousand has a bad experience with something, that news will travel at light speed and rampant. The other 999 will be silently content. |
| If you can obtain a copy of "Boats and Harbors" a yellow sheet that is published bi weekly , you will find loads of advertisers that will export parts etc, FF |
| Engine Surveyor? Take a look at: http://www.yachtsurvey.com/engines.htm and go down to the "Overhaul" articles. Dave Pascoe is a Marine Surveyor who's seen it all...
| Lunar, Plan on the repower and place your bid on this boat accordingly. The old "triple nickel" has a terrible reputation as a marine engine, and has been out of production for a long time. Do some research on boatdiesel.com. |
| I live near you and worked for Cummins Newcastle in the early 70,s when these 555 were new, I have extensive experience of them. And they are a very good engine, they got let down a bit pulling 45 tionne coal semis, around that area, with mainly 10 sp roeadranger boxes, they are a true high speed diesel and were not meant to lug they were a very good choice in thsoe days power to weight ratio Shortly afetr all thsi I started baotbuilding but retain interest Cummins i will be down you are soon or you can call me here if you wish 54561210 Stu |
| Cummins Engine Brochures Quote:
I prepared an Internet sıte named www.engine-cemberci.com www.engine-cemberci.com/engine/CUMMINS/4.pdf of Cummins 555 engine brochure is there. Oktay Çemberci İstanbul/Turkey |
| the absolutely astonishing thing and something that flattens me is that I posted a reply here early on, in this thread, offered my considerable experience, and even my home tel number. never ever received a reply So I say to anyone who starts a thread, looking for help, have the good grace to acknowledge |
