Go Back   Boat Design Forums > Design > Propulsion > Diesel Engines
Old 09-07-2010, 07:18 PM
Rep: 501 Posts: 1,767
Anyone have any ideas on reducing sand in shallow waters from coming in.
Old 09-08-2010, 05:35 AM
Bglad Bglad is offline
Rep: 67 Posts: 156
The owner of a 44' powercat relocated his raw water inlets from the bottom of the hull to the sides (still well below the waterline). I would think further away from the props would be good too.
Old 09-08-2010, 11:19 AM
apex1
Not a brilliant idea!
Having two intake scoops, one of either side of the keel, with generous diameter, reduces the suction force and sand stays out.
ahh, and the strainer (inside of course) should be of succifcient heigth to allow sediment to settle at the bottom.
Regards
Richard
Raw water intake strainer size seven up Inboards 4 11-06-2009 07:18 AM
removing raw water pump davemac Inboards 0 04-09-2009 04:57 PM
are raw water strainers a must? alibi Inboards 9 03-09-2009 08:47 AM
intake manifold water neck new2boatingguy Sterndrives 1 10-15-2008 11:05 AM
Help Changing Raw Water Pump bigdawg Powerboats 0 10-06-2006 08:42 AM
