Go Back   Boat Design Forums > Design > Propulsion > Diesel Engines
Old 10-12-2010, 04:19 PM
DennisRB's Avatar
DennisRB DennisRB is offline
Rep: 37 Posts: 435
80s vintage Yanmar 18 only hits 1800rpm
My girlfriends 31 foot sailing boat has a Yanmar 18hp and at full throttle the boat hits 5.5K. At this speed the engine is only doing 1800rpm and pumping a lot of diesel smoke. So we reduce throttle so the smoke stops. RPM only goes down a bit and speed is about 5K.
Do these symptoms sound like an over propped engine? What sort of RPM should this be reaching?
Old 10-12-2010, 04:29 PM
Rep: 1493 Posts: 7,447
That looks like a classical symptom of overpropping. Are there any identical or similar boats you can check the prop size?
Old 10-13-2010, 03:17 AM
DennisRB's Avatar
Rep: 37 Posts: 435
Thanks Gonzo. There are no identical or similar boats around that I can check. I will eventually dive down to scrub the bottom and measure the prop. I will also get exact engine specs.
Here is a pic of the boat. Not that it helps much but everyone likes pics Its unusual in that it has 7" draft on a 31" boat and huge free board for a 31". The boat looks huge next to other boats of similar length. Its strip plank. I think she said it is 5T?
Old 10-13-2010, 08:39 AM
Rep: 756 Posts: 3,328
Could be a cruise prop, could be a simple lack of fuel.
IF the smoke is mostly black , that's the sign of too much fuel , Cruise prop.
A 31 ft boat is probably 25 on the LWL , so 5K is the proper long range cruise speed , and 1800 is nice and quiet.
If you wish to add 1K at the cost of probably doubbling the fuel burn, some pitch can be removed from the prop.
Dive and be SURE its clean and not damaged.
FF
Old 10-13-2010, 11:49 AM
Easy Rider's Avatar
Easy Rider Easy Rider is offline
Rep: 694 Posts: 670
Simple enough. Just look at the specs on the engine. See where it develops max hp and tweak the prop till you achieve max hp rpm. You may want to use some Sea Foam to get rid of some of the black soot like stuff in the engine.
Easy Rider
what will happen when a hurricane hits Gulf spill? Squidly-Diddly Open Discussion: All Things Boats & Boating 217 07-12-2010 06:24 PM
evinrude 15 80s SWIFT HALF Outboards 4 01-14-2010 06:23 PM
Sailboat hits whale in Artemis Transat! WHALE PROOF BOAT? sailingaway Boat Design 36 09-13-2009 03:13 PM
Problems with my 15 horse evirude.. made in the '80s Jake29 Outboards 7 09-17-2008 03:37 PM
Mariner 28 (mid 80s) Boat Design 1 06-03-2002 02:59 AM
