| 360HP inboard for lobster boat Hi All I would like your views on which engine would suit my 33 foot lobster boat thanx ![]() |
| Any further data? Displacement or planing? Has it a weight? why 360hp, is that fix? One or two engines? |
| Currently has 360hp installed. Having trouble with that engine & wondered if anyone had a recomendation on a good engine.Planing hull,12is knots @2000rpm. Thanx |
| FPT engine Hi Lobsterman 1966 I can do you a trade deal on an FPT (Fiat Powertrain) N60 370 - 6 litre 370hp. FPT are a range of diesels to 865hp developed as a joint venture between Ford, Fiat and Cummins. By taking the best ideas from each manufacturer they have created a state of the art range of engines that are reliable, quiet, clean and very cost effective. Importantly they comply with current and future emissions regulations. Discounted price for the 370 is £13,950 ex factory ex vat. If you would like further information on this or any other FPT engine please do not hesitate to contact me Thank you Mark |
| "Currently has 360hp installed." But you may not be using a very large percentage of that power even at full throttle. What is your running home FUEL CONSUMPTION? Are you going thru 20 gph? How interested are you in "ultimate " fuel efficiency , compared to service life ? Most likely longest service life will be a non turbo mechanically injected engine, for lowest fuel burn a high pressure fuel common rail (30,000psi) with electronic controls and a variable output turbo . FF |
| Fred Can a tier II engine beat the BSFC of an old medium speed diesel when you are talking say 250-500hp?
__________________ Boat builders are not necessarily Boat designers who are not necessarily Engineers who are not builders who are not designers..... |
| Flat out 2500rpm ,I run at 2000 rpm & use approx 10 gph. Only run @ 2000 rpm for less than 2 hours per day |
| Lobster Boat - too much pitch and roll | shorelinedesign | Boat Design | 23 | 11-30-2005 04:49 AM |
| Lobster Boat | arif vidinli | Wooden Boat Building and Restoration | 9 | 07-21-2005 02:16 PM |
| 30 ft Lobster Boat project need investor | Guest-3-21-09-10-33 | Marketplace | 0 | 02-10-2005 04:07 AM |
| 36 sportfisher/lobster boat | joe | Marketplace | 6 | 09-23-2003 06:12 PM |
| 36 sportfisher/lobster Boat | joe | Boatbuilding | 1 | 11-04-2002 05:16 AM |
