Go Back   Boat Design Forums > Design > Propulsion > Diesel Engines
Old 10-20-2010, 04:02 PM
dskira dskira is offline
Rep: 1305 Posts: 1,372
Originally Posted by WestVanHan View Post
CT.
So long as it is designed and built safely,be as weird as you want.
One of my "hobby" businesses is importing stuff,items,interesting things.
Usually get free samples for cheap stuff, just pay the shipping.
I usually forget what I've ordered,so most days are like Christmas to me.
One thing I have is an engine like this,and I'm not sure on US laws but I'm sure they wouldn't like you to put it into a new built boat,can get them up to 27 hp twin.
Let me know if you want a link to a marine version.I imagine you could put in 2 of them,talk to your designer about that weight.
Not my video:
http://www.youtube.com/watch?v=3jxaX...eature=related
They are cheap...though myself I'd get a Deutz or Hatz.
West do waste your time. Some highly skilled professional abandoned after trying to make that crap work for more than ten years.
You find extinct web site about them, because people lost their patience.
Some are working after been rebuilt for thousand of dollars.
it is a very well known piece of junk. In other word don't touch it.
Daniel
Old 10-20-2010, 04:48 PM
Landlubber's Avatar
Rep: 1506 Posts: 2,456
Look also at the TE series of Yanmar, they were good engines, and plenty still available for recon jobs.
Old 10-20-2010, 05:06 PM
apex1
Originally Posted by cthippo View Post
The plan I'm working from specs a 107 HP JD 4045, and as TAD and others mentioned, with the extra windage a little extra HP would not be a bad idea. The sino-Deutz is a possibility.
If you are still talking about your 34ft boat, the Deere 4045 is already way overkill. And for what should it be good to install all these horses?
On another occasion you are saying you plan on a budget. Now you want to install a engine which either requires a CPP to survive your abuse, or has to be replaced in every other port.
For what?
The Deere would push your boat against the sails if need be, so, which windage are we talking?
Regards
Richard
Old 10-20-2010, 06:16 PM
cthippo's Avatar
cthippo cthippo is offline
Rep: 452 Posts: 725
For what?
Regards
Richard
What HP range would you recommend then? Most of the other boats I've sen in the 30-34' range have spec'ed 60-80 hp engines, but again I was going off what the plan called for.
Old 10-20-2010, 06:27 PM
apex1
Let us have some detailed data to give a serious answer on that. Guessing does not bring you any further.
It is a full displacement boat yes?
Old 10-20-2010, 06:36 PM
WestVanHan's Avatar
WestVanHan WestVanHan is offline
Rep: 413 Posts: 657
Daniel
I never recommended it to hippo,just giving him an idea of the crippling weight.
I don't have it to put into a boat,I bought it to re-sell and haven't gotten around to selling it.
And BTW, I know of a Lister copy in a commuter boat,been doing just fine 300 hours a year since 1989 or 1990.
I think it's bad luck to be superstitious.
Old 10-20-2010, 09:35 PM
cthippo's Avatar
Rep: 452 Posts: 725
Full displacement, design displacement of 21,000 lbs according to the study plans.
I noticed Tad's 39' Passagemaker Light with a design displacement of 19,600 lbs calls for 135 HP.
Old 10-21-2010, 06:36 AM
Rep: 756 Posts: 3,328
http://www.maesco.com/products/mar_prop/N67MNAM15.pdf
This is my favorite , good HP at lower RPM for a nice quiet cruise
Mfg estimates 8000+ hours in higher load applications.
FF
Old 10-21-2010, 08:35 AM
apex1
Tadīs boat is a "Passagemaker" aka Motoryacht! Not a motorsailor
And it does not need these horses (its a Deere 4050 when I recall right), but the market wants that power.
By design, Tadīs boat goes over S/L 1,34 and economically runs at speeds your boat will never see.
Still a bit meager your data.
Regards
Richard
Fred,
the Iveco is not a bad engine, but others do better at lower revvs. Deutz for example. 2800rpm is not what I call sensible in such boat.
  #25
Old 10-21-2010, 12:00 PM
liki liki is online now
Rep: 104 Posts: 169
Volvo-Penta D5A-TA has ratings for 1900rpm and 2300rpm.
  #26
Old 10-21-2010, 03:45 PM
cthippo's Avatar
Rep: 452 Posts: 725
Not a motorsailor
The design I'm working with is a pure motor vessel, no sails. It was developed by the NA and designer from a sailboat plan of his.
Unfortunately, all I have is what's in the study plans I got from the designer. These are his numbers, not mine. He specified a 107 hp for a 34' vessel with a displacement of 21,000 pounds. Any other numbers I could provide would be coming straight out of my rectal cavity.
  #27
Old 10-21-2010, 04:45 PM
apex1
I must have misunderstood, (probably from the drawing in the other thread) tah we are talking a motorsailor.
For a Motoboat, as mentioned, you are in the common ballpark.
But more important than another 20 hp is the prop. You should consider a CPP for a single engine motorboat!
Regards
Richard
  #28
Old 10-21-2010, 05:35 PM
cthippo's Avatar
Rep: 452 Posts: 725
Regards
Richard
OK, I can see how that happened. i posted pics of a couple of motor sailors from the same design family to make the point that the windage of the masts probably wasn't a big deal.
I'm sold on the CPP concept. Who makes a good one in this power range?
  #29
Old 10-21-2010, 06:03 PM
apex1
Westmekan, Hundested, Sabb come up in my head. But I never installed one in such small boat, so I am not sure. And being on the water, I donīt have my database at hand.
Lisa Williams the medium. Frosty Open Discussion: All Things Boats & Boating 13 07-08-2010 10:00 PM
Mid speed diesel engines Landlubber Diesel Engines 32 04-26-2010 09:27 PM
High speed Diesel/gasonline electric StianM Hybrid 5 03-07-2009 04:54 PM
Slow diesel ron17571 Diesel Engines 5 10-25-2006 11:57 PM
Slow speed but new engines. Vikendios Diesel Engines 8 07-27-2006 09:06 AM
