| 1 lunger diesel with adjustable pitch prop I saw a pic of an old 1 cylinder diesel with an adjustable pitch prop.Anyone know of a manufacture of these?The engine appeared to be from the 1920's or 30's. |
| I think Sabb and Bukh made them in the 60's. FF |
| Thanks.I'm considering 1 or 2 units,if I can find a matching pair,for a project I wanna build.Are the props manually adjustable on the go or oil pressure operated like an aircraft prop? |
| Hollow shafts and inner shafts move the gear to change the pitch
| Ahhhhh.Now I understand how it works.Shaft in shaft set up. |
| Hundested did not invent them, but make a very good quality CPP. Although not in that power range! Gori is the brand for such a small application. But you know that these engines you mentioned (SABB & BUKH) have a weight between 300 and 500 kg? Regards Richard |
| thank you for correcting me, how do you rate Gori engines & sterngear |
| Gori does´nt make engines. The props are very good and reliable. |
And here we have another manufacturer of small CPPs: http://www.spw-gmbh.de/ and big http://www.helseth.no/eng/products.htm and good http://zf-marine.com/Propulsion_Systems/index.cfm?PID=A Regards Richard Last edited by apex1 : 03-21-2009 at 10:00 PM. Reason: adding link |
| prop pitch | ems | Props | 2 | 03-15-2007 02:08 PM |
| prop pitch bmeasurements | spike | Props | 1 | 12-31-2004 11:03 AM |
| now do i measure prop pitch | gkelly | Props | 1 | 09-12-2004 05:58 AM |
| Drive Ratio and Prop Pitch | rayjay | Powerboats | 3 | 04-22-2004 03:07 PM |
| Need Info On Prop Pitch | Delta Explorer | Powerboats | 0 | 07-07-2002 09:48 AM |
