Old 01-24-2011, 07:59 PM
marinavaleng marinavaleng is offline
Rep: 10 Posts: 3
Yacht design in Rhinoceros 4
Hello everybody,
Can anybody help me about my questions and requests?
The main question is that how can I start to design a yacht in Rhinoceros.Actually Im familiar with rhino but I have never made a real yacht in rhino. I just want to ask that if you use the ship lines ? (I mean the drawings plan) or you just start with two surfaces ? Can you please explain me how to start ?
And second question also,Lets say that I use two planes to make a design, I canT choose the points that I want .Always I choose the otherone because they are always together ? how can I choose the point that I want.
And also a request. Can you help me to find some tutorials about designing yacht.(not normal rhino tutorials) I just want to see which ways normally do people use I want to know their experiences.if you have something like this or if you have something you made Could you please share it with me ?
Thank you for your help and kindness in advance.
Old 01-24-2011, 09:47 PM
duluthboats's Avatar
Senior Dreamer
Rep: 771 Posts: 1,580
Choosing the right point? Zoom way in, or if you pick the wrong one and it is in the way, pick it and hide it. Some of the Pros that visit here have written much about the "design process", search the design area.
Gary
"The hand feeds the mind."
Weston Farmer
Old 01-25-2011, 04:23 AM
b1ck0's Avatar
b1ck0 b1ck0 is offline
Rep: 28 Posts: 86
I am also interested in modelling techniques. It will be very helpful if you share your design strategy. Thanks in advance!
Old 01-25-2011, 12:29 PM
Senior Dreamer
This is a good contemporary look at the design spiral using CAD software.
http://www.newavesys.com/spiral.htm
There also is a long list of classic books on this subject and they can be found in this sites book store. My advice for hull design is start with a strong purpose and a very few well defined lines. Many great looking conceptual CAD models will rarely survive a trip down the design spiral. So don’t let the software seduce you.
Gary
Weston Farmer
Old 01-25-2011, 01:54 PM
DCockey DCockey is offline
Engineer
Rep: 1162 Posts: 1,656
I start with one surface to model one side of the hull. If the boat has a transom I add that as a separate surface.
Old 01-25-2011, 02:47 PM
Rep: 10 Posts: 3
Thank you very much for your advices and for your help guys.Starting with just one plane(surface) is also my method in maxsurf.But rhinoceros doesnT let me do whatever I want I canT do whatever I want and because of that I am asking another methods.Because its really difficult for me to transform just one surface to a hull shape in rhino. How do you do that ? whats your methods.? Please could you share your experiences with us ? and as I said above, Please share us if you have some tutorials that you did before or which are published in internet by another people. Because I looked for that tutorials everywhere but I couldnT find anything.There is just a blog about rhino and its not enough. Please share your experiences with us ..
Thank you very much in advance
Old 01-25-2011, 03:22 PM
Joe Petrich Joe Petrich is offline
Designer
Rep: 141 Posts: 158
It depends upon what kind of hull you are designing.
If it is a chined hull form you need to use 3 surfaces at the minimum: 1) bottom, 2) topsides and 3) transom. You cannot create a one surface chined hull in Rhino.
If you are creating a rounded hull form in Rhino you can use one surface and push/pull control points until you like it. Another way of creating a round hull form is to create section curves and loft through them.
Baseline Technologies has some relatively inexpensive tutorials for sale. See: www.basline.com
Rhinocentre also provides training and I think tutorials. http://www.rhinocentre.nl/
Good luck with your project.
Old 01-25-2011, 05:31 PM
Paul Kotzebue's Avatar
Paul Kotzebue Paul Kotzebue is offline
Rep: 272 Posts: 244
You can find a PDF file showing how to fair a simple sailboat hull in Rhino here:
www.pkboatplans.com/NA_Notebook.html
Paul R. Kotzebue, PE
www.pkboatplans.com
Old 01-25-2011, 06:33 PM
Rep: 10 Posts: 3
Hey thank you very much thats exactly what I want.
Thank you guys for all your informations... Is there anybody who wants to share something like this =) ?
Old 01-25-2011, 06:50 PM
Engineer
What type of hull shape are you trying to create? As Joe said different methods work for diffirent types of shapes.
As Joe suggests the easiest way to create a hull with a single chine is create curves for the sheer, chine, and bottom center profile (keel) and then use the Loft command to create surfaces between the sheer and chine, and chine and center profile.
Paul's tutorial is a good method to use for round bottom sailboats.
RhinoCentre in the Netherlands and Gerard Petersen have provided a tutorial and examples on how to model ships with bulbs: http://www.rhino3d.com/resources/dis...pl&listing=737
Old 01-26-2011, 06:47 AM
bhnautika bhnautika is offline
Rep: 547 Posts: 540
Joe Petrich try this to get a single surface chine hull
Create your three edge lines, sheer, chine and keel, then create the connecting surfaces (surface from 2,3,4 lines or loft with straight sections, you will have to exploded the lofted surfaces to separate them). Then use the “Merge Surface” on each surface to join them into one. They can then be edited using their control points. If you need to get back the separate surfaces use either the “divide along creases” or “split at isocurve” commands. For those who are interested I have supplied a file in rhino 2 format of the three steps.
Old 01-26-2011, 02:27 PM
Designer
Rep: 141 Posts: 158
Thanks Bhnautica. I never need to create chined hulls as all one surface so forgot about the mergesrf command for doing it. Thanks for the reminder.
Old 01-27-2011, 01:05 AM
Rep: 547 Posts: 540
Joe there wouldn’t be a need if you could only edit polysurfaces in rhino!
Old 01-27-2011, 02:21 PM
Designer
Rep: 141 Posts: 158
If you have Rhino 4.0 have you tried Cage Edit? It can do some interesting things with polysurfaces.
Old 01-28-2011, 05:43 AM
Rep: 547 Posts: 540
Joe yes I have used the cage edit for a whole surfaces edit but I find the changes it sometimes makes to the number of control points of the surface a bit of a nuisance if I need to make some localised change later on. I am of the less is more philosophy when it come to control points.
Rhinoceros sunadria Boat Design 6 03-27-2010 12:27 AM
modeling hull of tanker ship in Rhinoceros jozo_bozo Software 6 10-27-2009 07:48 AM
Hull Modeling With Rhinoceros Antisthenes Software 14 08-08-2008 03:41 PM
Rhinoceros 4 RELEASE CANIDATE 1 announced today020207 Antisthenes Software 0 02-02-2007 07:52 PM
Hydrostatics in Rhinoceros Software 10 06-24-2002 01:27 AM
