Old 06-08-2010, 01:53 AM
Guest62110524 Guest62110524 is offline
Previous Member
Rep: 0 Posts: 0
can anyone explain , in simple lingo, what a closed planer loop is, , I can not seem to make a surface here
thanks
Old 06-08-2010, 02:03 AM
Martijn_vE's Avatar
Martijn_vE Martijn_vE is offline
Marine software developer
Rep: 401 Posts: 252
thanks
A closed planar loop is a set of connected points (closed means the first point is connected to the last point) all in the same plane. Like a circle or a rectangle for example.
Old 06-08-2010, 02:17 AM
Previous Member
Rep: 0 Posts: 0
well a warped , entity like a boat topside, Martin, CAN NEVER BE ON ONE PLANE, LESS ITS A BARGE, scuse caps, and danke
Old 06-08-2010, 02:19 AM
Martijn_vE's Avatar
Rep: 401 Posts: 252
That's correct.
Warped and planar are contradictionary.
Old 06-08-2010, 02:21 AM
Previous Member
Rep: 0 Posts: 0
That's correct.
so if I use edges?
or how would I make the surface?
