Old 04-08-2012, 01:21 AM
Laranjo123 Laranjo123 is offline
Previous Member
Rep: 34 Posts: 140
ah i c sir sorry. But i only used Acad ......to confirm that fact hehe...
Old 04-08-2012, 01:30 AM
Previous Member
Rep: 34 Posts: 140
bhnautika so sir what's your rate ?.. 1-10 sir?...i need to have a survey reagarding to my render. Because the client needs the render to make brochures regarding to this yacht....They're about to sell this lady. hehe
Old 04-08-2012, 08:46 AM
bhnautika bhnautika is offline
Rep: 566 Posts: 602
Laranjo123 if you are going to use this for a brochure you will probably have to increase the resolution and DPI. I would also add some more lighting as it is a bit on the dark side, possibly the classic three spot lights arranged around the subject or increase the ambient light so you can see what’s there (see pic). Framing the subject and camera angle can make a difference to the way it looks. Also I noticed that there is one part that is floating above the fly bridge deck?
Old 04-08-2012, 10:19 AM
Previous Member
Rep: 34 Posts: 140
Here's the last sir i'm gonna add lights by tomorrow i'm tired...hehe thank you sir for your advises. I really appreciate them.
https://www.facebook.com/photo.php?f...type=1&theater
And this one was rendered using Autodesk Showcase 2012
https://www.facebook.com/photo.php?f...e=1&permPage=1
Old 04-08-2012, 10:23 AM
Previous Member
Rep: 34 Posts: 140
Where? At fly bridge deck?...it's a bug i think...?It's really hard to make a 3d when i'm only using this lappy top hehe... Someday i'm goingto buy alienware pc hehe...To make things faster....
Old 04-08-2012, 08:46 PM
Rep: 566 Posts: 602
Laranjo123 the render that was done with Autodesk Showcase is a lot crisper than the earlier renders. The area I mentioned earlier (see pic)
Old 04-15-2012, 05:56 AM
Previous Member
Rep: 34 Posts: 140
Lols i did not notice that one hehe.... Thanks sir.. O___O
Old 04-15-2012, 02:48 PM
DavidJ DavidJ is offline
Rep: 441 Posts: 189
There are countless rendering engines out there that will produce the photorealistic looks. You'll just have to find the one that suits your budget and works well for you. Most of them have plugins for Rhino. Some modelers like 3DS max, Maya, and others include high end render engines. Some renderers have more options, some claim to be easier to learn, some claim to be easier to setup, some claim to render faster. You can try out demos to see what works for you. You could also check out other forums that specialize in computer art, such as CGarchitect.com and look for hints and tricks. In the end which software you choose really doesn't matter. It's your skill and knowledge of how to get what you want out of the software and your understanding of lighting and composition that will make the great shot.
Some popular render engines:
Maxwell
Brazil
V-Ray
Bunkspeed
Keyshot
Old 04-21-2012, 11:42 AM
The Loftsman's Avatar
The Loftsman The Loftsman is offline
The Loftsman
Rep: 41 Posts: 57
Maya will produce the best rendering you will get, but as an all signing and dancing CAD system to do it all including realistic rendering then it has to be Catia.
"Fairline" A line that is pleasing to the eye!
www.leithshipyards.com
http://leithbuiltships.blogspot.co.uk
  #25
Old 04-21-2012, 11:56 AM
Rep: 441 Posts: 189
There is no such thing as the best you can get. It comes down to each individuals skill and willingness to learn the software. Maya comes with the same rendering engine that comes with 3DS max, mental ray, which while very powerful can be difficult to learn.
Catia really doesn't belong in a discussion of render engines. Catia costs a fortune and has no built in photorealistic render engine (although plug-ins are available). Catia is a high end design package that is more appropriately compared to ProEngineer, NX, or a suite of autodesk products.
  #26
Old 04-21-2012, 12:10 PM
The Loftsman
Rep: 41 Posts: 57
But will it float!
Opinions, opinions, opinions-What makes the world go round eh!
That and good old fashioned experience as you say.
  #27
Old 04-22-2012, 04:19 AM
Rep: 566 Posts: 602
One other thing that might be a consideration is the hardware to drive all this software, the spec’s of his present hardware mentioned in the early posts may not be up to the job of driving any of these programmes. Also the price to be payed for the end product in software and time in leaning could be prohibitive. Programmes like Maya and 3ds max are around US$3500. Some of the standalone renderers are US$1000. Then price in the new hardware and you are looking at a sizable investment for the end result of the perfect picture. There are however a number of free or low cost programmes available which can give good results, Blender, Carrara, Hexagon ,trueSpace and DAZ studio come to mind but in the end, leaning about what you have may be more productive.
  #28
Old 04-23-2012, 08:21 AM
nautique210's Avatar
nautique210 nautique210 is offline
wake master
Rep: 16 Posts: 22
You should be able to get the results you are after with Showcase if you can use a decent workstation (with at least a high end GPU, even if it's the old generation).
Just ensure the following;
- use an environment with image based lighting. I have a nice HDR reflection map, let me know if you want it.
- fix all of your normals and calc the ambient occlusion to a high res.
- set the Raytracing to a high res too. (these last two can take a long time to compute)
I always add a plane for the waterline, so you can adjust the transparancy and reflections without having to worry about the envronment floor. Can normally get renderings like the gallery you linked to done in about 15 mins.
Cheers,
Shaun
  #29
Old 05-21-2013, 04:30 PM
AJ0954 AJ0954 is offline
HDRI Reflection Map
Hey Shaun,
Is it possible that you still have the Reflection Map you mentioned above?
I am working on renderings in Showcase and it would help me very much.
If you have any environment files, HDRIs, or anything else that helps that would be great as well.
Thanks,
AJ
Cheers,
Shaun
Maxsurf Render problem vitaegosum Software 5 09-29-2008 05:09 AM
Render in Rhino 3 catsketcher Software 2 05-16-2007 12:03 PM
3d render tz3dcom Services & Employment 0 05-16-2007 05:04 AM
Rhino render ARGO Software 2 05-16-2005 09:36 AM
Great RENDER!!!!! desi Software 1 12-28-2003 09:49 AM
