Old 12-26-2009, 12:19 AM
pavel915's Avatar
pavel915 pavel915 is offline
Rep: 154 Posts: 319
wave lenght by Michlet
is it possible to find the wave length of transverse wave system so that i can see whether my ship is operating in displacement or planning region for a particular speed?
If yes, then how?
Md. Al-Amin Pavel
http://www.paveldesign.tk
"A question that sometimes drives me hazy, am i or are the others crazy?"
Albert Einstein
Old 12-26-2009, 06:08 AM
Leo Lazauskas's Avatar
Leo Lazauskas Leo Lazauskas is offline
Rep: 1816 Posts: 1,422
If yes, then how?
The wavelength of "pure" transverse waves is
Lambda = (2 * pi * U^2)/g
where
U = ship speed
g = gravity
This wavelength, however, does not tell you anything about whether a hull is, or is not, in "planing" mode. You have to find some other method.
All the best,
Leo.
Old 12-26-2009, 06:17 AM
pavel915's Avatar
Rep: 154 Posts: 319
Thanks Leo for your reply,
Actually i knew the equation you have written,
But i am confused that, does not the wave length depend on the hull form at all? For any kind of hull the wave lengh will be equal to ships lenght at Froude number 1/Square-root(2Xpi) ?
Md. Al-Amin Pavel
Albert Einstein
Old 12-26-2009, 10:23 AM
Yes, the wavelength very close to the hull is affected by the shape of the hull. But you asked about the wavelength in Michlet.
Michlet results are only valid behind the hull, i.e. it only calculates far-field waves using linear wave theory. In that case, the wavelength of pure transverse waves in deep water is given by the equation I gave previously.
To see the separate near-field and far-field components see, for example, the SWPE report at:
http://www.cyberiad.net/library/pdf/tsl00a.pdf
Leo.
Leo.
Old 12-26-2009, 11:10 AM
pavel915's Avatar
Rep: 154 Posts: 319
Thanks Leo,
I get it now,
Md. Al-Amin Pavel
Albert Einstein
Old 12-27-2009, 12:38 PM
Rep: 1493 Posts: 7,447
You are overthinking the problem. A planing hull is running over the bow wave. The wave has the lenght of the boat's waterline.
Old 12-27-2009, 08:16 PM
And you have grossly under-thought the problem
Displacement boats can operate at a Froude number where the wavelength is exactly same as the boat length. And planing hulls at exactly the same Froude number may not actually be planing.
Cheers,
Leo.
Old 12-27-2009, 09:56 PM
pavel915's Avatar
Rep: 154 Posts: 319
Actually i was trying to talk about the highest speed upto which a displacement boat should operate,(may be called transition between displacement and semi-displacement) i.e. where the wave length is equal to the boats lenght. But i was confused about whether this wavelength depends on the hull form or not,
Leo has made this clear to me,
Md. Al-Amin Pavel
Albert Einstein
Old 12-28-2009, 04:06 PM
The wave length depends on the waterline length. However, the hull shape can have different waterline lenghts at different speeds. This is used to advantage on sailboats.
Old 12-28-2009, 08:57 PM
Not in Michlet.
The wavelength of the transverse wave system is given by the equation I gave earlier. Hull length does not appear in that equation.
Leo.
Old 12-29-2009, 01:09 PM
terhohalme's Avatar
terhohalme terhohalme is offline
Rep: 478 Posts: 485
Gonzo, no
I ask you to repeat your tank tests.
Only shared knowledge can grow.
Michlet pavel915 Software 73 01-17-2010 08:46 PM
Michlet for retroactive wave-generation Metatron Software 14 09-21-2009 12:45 PM
Frameless steel hulls: Is there a lenght limit? xarax Metal Boat Building 19 02-05-2008 11:58 PM
Maxsurf: lenght of curves Red at Night Software 3 08-11-2005 04:46 PM
Sailboat Lenght Capt'n Laddie Sailboats 3 06-23-2004 06:40 AM
