| Want Xfoil, do I need Unix to use? I want to play around with some foil shapes for my I14 and it sounds as if Xfoil is what I need. Seems XFOIL requires Unix. Are there other options? I'm not the brightest on the block when it comes to software requirements, so speak slowly ![]() |
| There are versions of Xfoil available for 32-bit Windows versions as well as for Unix-like systems. It reportedly runs just fine on Windows XP, 2000 and NT, but may not get along so well with older versions. See http://web.mit.edu/drela/Public/web/xfoil/ It also has a bit of a users group at http://groups.yahoo.com/group/xfoil/ Xfoil, like most research code, comes in pieces and operates through a text console. If that's intimidating for you, you might check out JavaFoil ( http://www.mh-aerotools.de/airfoils/javafoil.htm ).
| Javafoil has a much friendlier interface. It will take less effort to get results from it. Rick W |
| Matt and Rick, Thanks for the advice. I might try the original version, sounds like you feed it text input files like the old Fortran programs we used to put together in school. -Steve |
| Xfoil in batch mode | fastwave | Software | 1 | 12-13-2007 03:09 AM |
| Any help appreciated: Airfoil design and using xfoil | bwoo | Boat Design | 9 | 04-26-2006 05:05 PM |
| XFOIL for hydrofoils | boogie | Boat Design | 10 | 02-07-2004 02:52 PM |
| XFoil - NCrit | nico | Software | 0 | 10-10-2003 03:43 PM |
