| Vectorworks question is it possible to use a spline as a trim edge?, and, are there any other splines types in vectorworks? the tool that i'm using to draw the spline is called "Nurbs curve tool". Thanks for the help |
/Claes
__________________ Claes Lundstrom |
| Thanks Claes thanks for your help actually that was another question that I had, but I didn't explain myself correctly in the first one what I meant to ask is, for example if I draw the 2D profile of a boat, and my sheer and fairbody are sketches drawn with splines can a I use this spline to trim lines, circles or polylines? Many thanks for the help |
Make user that the Spline is on top of the object to be trimmed (Tool menu -> Send -> to Front, etc if not) and then use Tool menu -> Clip Surface. Despite it's name this command also works with non-surface objects.
| Thanks claes for your help, but still i can't make it work, and i have this message (see image), i will keep trying to found out what i'm doing wrong Thanks for the help |
| Thanks Claes i got it, and is working fine!, many thanks for your help |
| Hull enlargement question?? | jackason | Boat Design | 3 | 09-09-2005 07:03 PM |
| Introduction and a Question | AndyC | Open Discussion: All Things Boats & Boating | 16 | 07-13-2005 04:44 AM |
| I/O to Inboard Conversion; DWL Question | MDuff | Powerboats | 7 | 11-23-2004 04:04 AM |
| Planing hull question | graham | Boat Design | 10 | 12-13-2001 04:40 PM |
| Planing hull question | graham | Powerboats | 1 | 12-09-2001 04:13 AM |
