Old 04-04-2007, 06:12 PM
erinh erinh is offline
Unfolding & Importing from SW to TC
Hello-
I'm trying to import a solidworks part file into touchcad, and am having trouble. Is there a correct way to do this? I now that the import options are limited in touchcad, and I may be out of luck.
Also, I am wondering if it is possible to import a 3D model from Solidworks into Rhino. If so, is it possible when using rhino to unfold/flatte a 3D model into 2D panels?
I have read through the forums and could not find these answers, so thanks for the help.
-Erin
Old 04-05-2007, 06:20 AM
ludesign ludesign is offline
Rep: 54 Posts: 181
Originally Posted by erinh View Post
Hello-
-Erin
Send the file to info@touchcad.com
Claes Lundstrom
Old 04-05-2007, 10:15 AM
CGN CGN is offline
Rep: 138 Posts: 547
erinh send your file to ludesign he will figure it out, and should be the best way to go for you, and about solidworks, just save the solidworks file as an iges or step, i don't recall being able to save from solidworks as a .3dm (maybe now is possible) but should work just fine and yes you can unfold or develop a surface from solidworks once in rhino (if the surface is developable). if not they do have a new plug in that can help you.
cheers
Old 04-05-2007, 10:18 AM
Steve Baer Steve Baer is offline
Rhino Developer
Rep: 64 Posts: 90
Hi Erin,
You should be able to open a solidworks file directly in Rhino. Rhino has tools for flattening surfaces, but not unfolding. If you are looking for flattening tools in Rhino, look up UnrollSrf and Smash in the Rhino help along with the new Squish tool available on the Rhino Labs page:
http://en.wiki.mcneel.com/default.as...lattening.html
Thanks,
-Steve
Importing tables of offsets from Excel to Freeship Troutcatcher Software 2 12-19-2006 11:20 AM
importing iges to Maxsurf DaveB Software 3 05-11-2006 08:04 AM
Importing into Freeship LP Software 4 10-14-2005 03:56 PM
software for image unfolding? servilletanegra Software 4 12-17-2004 04:22 AM
Unfolding formed boat panels to flat sheet Rohan_Tink Metal Boat Building 3 02-23-2004 10:02 PM
