| Understanding "TRIM" in Freeship hydrostatics? I've got a 22' power boat design that requires a trim value of -.100 feet (1.2") to move the LCB aft about 5" to match the LCG. My question is this: How do I locate the new waterline in the profile view? Thanks.
__________________ Denny Wolfe www.wolfEboats.com |
| Just rotate the hull around the y-axis ("Transform" -> "Rotate"). You need to calculate the rotation angle to match the desired trim of -1.2" first or do it the trial-and-error way. Most likely you have to adjust the draught also to maintain your design displacement.
__________________ All the best, Olav GER-1045 ____/)_/)/)___ |
| Thanks, Olav. That was easy.
| "FreeShip" or similar running natively on OS X? | CatBuilder | Software | 10 | 01-26-2012 08:13 AM |
| Canoe "Stability Factor" w/ Freeship | Tim Hall | Stability | 14 | 05-15-2011 11:15 PM |
| Bennett Trim tabs, with "tracking" fins | duke | Boatbuilding | 1 | 01-18-2010 01:06 AM |
| Freeship Hydrostatics Trim | goolawah | Software | 2 | 08-22-2006 04:30 PM |
| "Freeship" hydrostatic stats analysis of three ships | jedclampit | Software | 17 | 02-23-2006 08:28 PM |
