Old 08-21-2007, 05:31 PM
Rep: 700 Posts: 691
Undeletable phantom in Rhino
I think I have fixed this before in the dim past but can't remember how so I throw myself at the collective feet of the forum.
I have a small piece of my model in Rhino that has gone bad. It is a small section of cabin side and I can't select it, move it, hide it, delete it or do anything with it. The only thing I can do is turn it off by turning off the layer. No modification other than that.
I did some diagnostics and Rhino found 3 bad objects but didn't delete this one. I am about to change all the other parts of this layer to a temporary layer, delete the layer with the unmodifiable part on it and then rename the other layer. Is there a more elegant way to do this? It seems a little roundabout.
I thank any contributors in advance, I do feel a little sheepish on this forum as I always seem to have my hand out. I try and make up for it on the multihull and sailboat section. Boats are my passion whereas computers are a tool for me.
cheers all
Phil Thompson
Old 08-21-2007, 05:43 PM
ericCB ericCB is offline
Rep: 10 Posts: 4
possible fixes
possibilities...
check your blocks,
check your hidden parts,
make sure you didn't lock the layer
close and reopen rhino and file
check for software release updates
Hopefully that can help,
Eric
Old 08-22-2007, 10:25 AM
pgolay pgolay is offline
SelbadObjects
Hi Phil- I usually find Selbadobects and Delete does the job if there is an unselectable object in the file. (Most likely it does not have any edges or something). If this does not work, that is if SelbadObhects tells you it selects the thing but it is still around after Delete, the layer technique should do it, but if you could send me the file at pascal@mcneel.com that would be good, I'd like to have a try at it myself.
thanks,
Pascal
Old 08-23-2007, 03:23 AM
Rep: 700 Posts: 691
Thanks
Thanks Pascal and Eric,
I tried most of your suggestions (apart from updating to Rhino 4). Still no luck. Swapping layers took 5 minutes so it wasn't really a problem. Just thought that I was missing something.
cheers
Phil Thompson
2D Rhino to Autocad export and rhino sectioning fede Software 13 10-18-2009 02:55 AM
Coremat used in Sunfish (Phantom) bigdog9801 Sailboats 2 08-10-2007 07:09 AM
Rhino 3D futuredesigner Software 5 09-14-2006 08:42 PM
PHANTOM DRIVE SYSTEM 60% less fuel CAJIN Propulsion 5 07-05-2006 10:13 PM
Rhino blewett_john Software 29 01-18-2003 05:05 AM
