Old 02-22-2007, 02:43 AM
kalada kalada is offline
Rep: 10 Posts: 4
...Two Multisurf questions...
Hi All,
I need an expert advice on this Please refer to attached examples:
1) 3D_sheer.ms2
this particullar ProcCurve construction in MS5 is rather unstable for AbsBead AA beyond t=0.99 with accompanying 303 error code. Does anybody know how it could be solved?
2) knotlist_2.ms2
does anybody know the reason for this NURBcurve with knotlist2 only partially beeing drawn ?
I'd really appreciate any help
THANKS!
kalada
Old 03-01-2007, 08:05 AM
Rep: 10 Posts: 4
...no entrances?...well, I'll try to reach the answers myself then, through the some kind of monobrain storming But public, off course...and it would take some time too...
ad1)...it seems that ProcCurve is sensible on horizontal projection entrance angle. As it nears the 90deg the sheer is less stable ?!?...
ad2) ?...blank...
Old 03-01-2007, 02:41 PM
snakefeet snakefeet is offline
Rep: 10 Posts: 24
I'm not sure how much this will help you but FWIW I have had nothing but disappointing results from proc curves and proc surfaces. They sound great in theory but in practice (and I can only speak from my own experience) they fall flat.
If I was making that sheer curve I would be inclined to build a transverse surface based on the upper knuckle Bcurve (relcurve the upper knuckle & cloft between them) and project the upper lower knuckle Bcurve onto the surface as a snake.
I must confess that i have never used a knot list & would be of even less help in that file.
Cheers
Sorry, I left my witty sig in my other newsgroup.
Old 03-04-2007, 05:01 AM
Rep: 10 Posts: 4
...thank you snakefeet...this sounds much like my own plane B...but I have that bug called curiosity I won't be at rest till I found the REASON WHY...Strange that AH haven't fix problem with the proc entities yet
Old 02-02-2009, 03:19 AM
zeroname's Avatar
zeroname zeroname is offline
Naval Architect
Rep: 90 Posts: 262
hy...
what is the difference between multisurf and surfaceworks_marine? is there any major differences?
Old 02-02-2009, 09:33 AM
aleutka29 aleutka29 is offline
Rep: 10 Posts: 10
ProcCurve Fix
The problem of un-stability on Procedural entities has been fixed in the most recent versions of MultiSurf.
Contact AeroHydro to download your evaluation version.
Old 02-02-2009, 09:39 AM
Rep: 10 Posts: 10
SurfaceWorks Marine is no longer offered. It was packaged that way to make a distinction as having a different user interface than MultiSurf.
Now all functionality is moved to the new interface and the brand MultiSurf is for all marine users and the SurfaceWorks brand is for the Industrial Design customers. Both programs can be integrated with SolidWorks.
Various Questions KI4NCW Metal Boat Building 30 02-02-2007 06:30 PM
Some questions. fcfc Option One 10 11-05-2006 04:39 PM
Stations in Multisurf: help!! Akeswins Software 0 12-11-2005 11:34 AM
Exporting DXF from Multisurf to MAXSURF Akeswins Software 6 09-30-2005 05:19 AM
MultiSurf questions... Guest Software 2 04-22-2003 02:49 PM
