| Tutorial Hello, I am having a go at creating my own "dream yacht". I have aquired Surfaceworks marine, although used to Catia ( 8yrs Automotive.) What I am looking for is the general sequence of hull creation, are there any tutorials out there.? thanks Howard
__________________ Just........Swanning around |
| if you download feeship, or delftship, (free) it starts a new design with your parametres, you can either stick with the round bilge default or change to chines, from there you can send your lines to your CAD programme |
A good design starts with a clear specification based on your priorities. I have started learning about hull design after owning a number of different boats. I am as much interested in the design and what is possible as actually using the boat. I have learnt that using boats for enjoyment requires lots of time so my next real boat is my retirement project. My priorities are: 1. Primary safety - strength to handle heavy and hard grounding, always buoyant even if swamped, self-righting 2. Secondary safety - speed, sea kindly, stability, pointing ability, redundant propulsion systems 3. Practical - easily handled by one person, operate with autopilot most of the time 4. Building and operating costs - has to be a hobby not a life 5. Comfort - good sleeping for a week or two, good working area 6. And so on I have learnt a lot about displacement hull efficiency from building pedal powered boats. The viscous drag is easy to determine but wave drag is much more difficult. I use Leo Lazauskasus Michlet/Godzilla to optimise hull shape allowing for wave drag and it has proven very reliable for my operating regime. I use Freeship (now Delftship) to draw up hulls as this interfaces well with Michlet. Once you have your priorities sorted out you have a starting point for the size of boat you would like and starting point for developing a detailed specification. This allows a rough calculation for displacement, design speed, stability and so on. The design is an iterative process trying to achieve the best compromise to suit your priorities. Rick W. |
| Hi, I am more interested in the actual practice of producing the curves/surfaces. My experimentations are not producing the desired effect and I am ending up "patching" in awkward areas. I already have a layout and hull form in mind, quite similar to my own S&S. thanks Howard
Rick W. |
| This will help you learning how to lay out a hull, there are many ways to do it this is only a good tutorial on how to model a hull using this technique: http://www.cadjunky.com/index.php/ma...how?id=3805430 And i y ou go here you will find tutorials for surfaceworks and multisurf http://www.aerohydro.com/tutorials.htm Also have a look at the maxsurf site i think they have some tutorials, this programs may be different but the techniques should work |
| Hi, Thanks for that, these sites are a big help and didn't come up on any searches, thanks. I hope to produce an aluminium Swan 411 and adapt it to centre cockpit with a stern stateroom, purely acedemic at this time, but, you never know. thanks Howard
| Shipconstructor tutorial help | stephen gibson | Software | 3 | 06-18-2007 02:07 AM |
| michlet tutorial | pavel915 | Software | 7 | 03-07-2007 07:49 PM |
| Rhino tutorial | Al_Rassan | Software | 1 | 05-10-2006 04:52 PM |
| FastShip Tutorial | Vibtor | Software | 1 | 11-26-2005 03:27 AM |
| Propeller tutorial? | duluthboats | Software | 16 | 10-09-2003 12:32 PM |
