Old 04-04-2008, 11:26 AM
pavel915's Avatar
pavel915 pavel915 is offline
Rep: 154 Posts: 319
Traditional Shell expansion drawing in Rhino
I am trying squish plugin to do shel expansion drawsing.
before squish ; i split the hull surface by drawing curves on the surface; and then try squish.
But it unrolls individual sections of surfaces not all the splitted surfaces togther as in the traditional shell expansion drawing.
I tried to arrage the expanded surface after squish; but i could not do it becouse when the surfaces are expanded; they become spread in a irragular pattern.
Can anyone suggest how can i get the shell expansion drawing in rhino?
Old 04-04-2008, 12:25 PM
duluthboats's Avatar
Senior Dreamer
Rep: 771 Posts: 1,580
I'm not sure if Rhino will do what you want using the squish tool. It is under developement and maybe it will work some day. Look for posts on this forum by Brent Swain I think he is the origami guy here. This type of expansion has to be designed in from the start.
Gary
"The hand feeds the mind."
Weston Farmer
Old 04-04-2008, 02:40 PM
CGN CGN is offline
Rep: 138 Posts: 547
Pavel
You can't use any of the development tools, these gives you the true shape of the expansion.
you need to do it manually extending each of the frames or station, i don't think there is any tool that can do it in rhino.
can be done manually on rhino
Old 04-04-2008, 10:25 PM
Gilbert Gilbert is offline
Rep: 28 Posts: 512
If it is a chined hull isn't the loft command what you want to use?
Old 04-05-2008, 08:22 AM
pavel915's Avatar
Rep: 154 Posts: 319
Hope Rhino will soon release plugin for this. Becuz in rhino spliting the surface is soo easy than other softwares like Workshop.
Drawing surfaces of the bulb in Rhino toda Software 7 04-19-2007 06:18 AM
shell expansion and midship section drawing in workshop pavel915 Software 5 02-27-2007 02:27 AM
unroll surface in rhino for shell expansion pavel915 Software 4 02-16-2007 07:35 AM
traditional designs and traditional methods chandler Sailboats 50 12-22-2005 05:36 PM
Rhino drawing of Racing Chair and Machine Gun Vibtor Boat Design 1 10-03-2004 07:05 AM
