Old 11-19-2005, 08:30 PM
dongtao dongtao is offline
Rep: 10 Posts: 6
is there an free software for propeller design?
is there any free software for propeller design?I mean that you give the parameter of the propeller, the software can give you a 3d propeller model, just like PropCAD, but PropCAD is so expensive.thanks in advance.
Old 12-17-2006, 12:44 AM
branet branet is offline
how much does it cost? I don't think so .it's not so expensive.i've heard it is about 800$ for 5 seats network.is it right?
Old 12-17-2006, 08:25 AM
Figgy's Avatar
Figgy Figgy is offline
Rep: 88 Posts: 315
Without knowing what you want to do, maby you could start with this. http://www.mh-aerotools.de/airfoils/javaprop.htm
(it's Java, click on "The Applet" in the left frame) Its not really what your looking for, but it is free, and it is propellers.
If your really into designing props, IMO PropCad is the way to go.
Imagination is more important than knowledge.
-Einstein
Old 12-17-2006, 09:18 AM
Rep: 10 Posts: 6
branet: I think "expensive" is a relative things. I am a PHD candidate in China, my salary is RMB300, that is less than $40, . If I were a PHD students in USA or Europe, I think i could afford it for $800.
Figgy: The hyperlinks you give is not available for me in China?
Old 12-17-2006, 10:47 AM
yipster's Avatar
yipster yipster is offline
Rep: 1083 Posts: 3,337
did you try the bottom line applet in the menu?
nice applet and works fine here, thanks figgy
Old 12-18-2006, 11:33 AM
Rep: 10 Posts: 6
The web site you give is unreachable for me, could you give me a local copy of javaprop? my mail is: dongtaomail@gmail.com. thanks!
Old 12-18-2006, 11:55 AM
nico nico is offline
Rep: 52 Posts: 186
looks like the chinese government is blocking a java tool to design propellers, nice work .
____________
Nico
Old 12-18-2006, 12:52 PM
Tim B Tim B is offline
Rep: 794 Posts: 1,407
Surely a PHD student could write a bit of code to generate a propeller, given
Diameter
BAR
Pitch
twist rate
rake
sweep
and perhaps a few others...
Now the tricky bit is to analyse the propeller, and if you really want to improve on what's there already, optimise it.
Tim B.
Old 12-18-2006, 01:24 PM
yipster's Avatar
had to compres ( now 565 bytes) couse java applet ( 969 bytes ) is not supported for upload here
hope it still lives, java 1.5 must be installed on your machine
and eh, get china a normal i-net please
File Type: zip javaprop.zip (565 Bytes, 972 views)
Old 12-20-2006, 09:05 PM
tm75tm tm75tm is offline
Rep: 10 Posts: 7
use anonymouse clients
I am currently working in China and have this problem often.
use either proxify.com or anonymouse.org to get around the great (fire)wall of China.
Trev
Old 01-18-2007, 02:25 PM
mrs500g mrs500g is offline
Rep: 10 Posts: 5
Just to let you know that, if you use a program called designfoil (http://www.dreesecode.com/) then you can create the geometry sections of the propeller blade. This program is used for airfoils but they are the same as marine propeller blade sections and then you can import them into solidworks which you can create you propeller in by lofting it.
It's only a five trail version of the program but there are ways round this by deleting one of the file it creates when you open the program
Old 05-03-2007, 12:58 PM
Çemberci's Avatar
Çemberci Çemberci is offline
Rep: 133 Posts: 117
Dear
Are you close or cooperation with Propeller Casting as we
http://www.cembercidenizcilik.com/dokum/index.htm
If you give me size of propeller that you calculated.
I will draw your model as attached file.
Size of Propeller
Diametre
Pitch
Dar
Model (Attached Çemberci File)
Blade Number
Oktay Çemberci
Solomon Technologies - "Electric Wheel" electric motor propulsion systems lockhughes Hybrid 228 10-12-2011 04:00 PM
Master in yacht design ambas Education 26 05-11-2006 01:47 AM
Option One - how big Willallison Option One 43 12-20-2005 05:44 AM
