| Tapered Fillet in Rhino I'm wondering what the best way of producing what I would call a 'tapered fillet' in Rhino. The fillet would be between the bottom and what is essentially a box keel, that stops some way short of the transom. I'm tring to create a smooth 'joint' between the two surfaces up fwd that hardens to a tighter radius aft. A simple fillet in Rhino produces the opposite.
| Maybe edge curve or curve network, place the start radius and end radius along with the surface edges.
__________________ "The hand feeds the mind." Weston Farmer |
| Will, You can either use the variable radius fillet command for unjoined surfaces or the filletedge command for joined (poly) surfaces. Both allow you to set the type of radius (rolling ball, distance from edge, or distance between rails), and to add points where you can change the radius if needed. If you learn to use these commands I am sure you will get what you need. It helps to dock the help window on the left or right side of the screen. Then when you enter a command the help menu shows how to use the commands, sometimes with a little video as well (click the arrow in the bottom left corner of the image to run it). This all assumes you are using Rhino 4 with the latest service release. The Rhino newsgroup is also a great place for questions. You will usually receive an answer from Rhino staff or experienced users very quickly after you post there. |
| Thanks Gary, Joe I'm afraid I'm still with my trusty old Rhino 3. I'll have a bit more of a play and see what I can come up with. Otherwise, I may to re-examine how I've built the model in the 1st place... that or an update to R4....
| Oh - and re placing the help menu... I use two screens.... I don't know how I ever got by with one!
| Well if you don't have Rhino 4 then a work-around is to create a pipe using the edge of the keel/hull intersectiopn as your pipe centerline and giving different radii for the start and end. Then trim the two surfaces with the pipe. After that use blendsrf between the two surfaces. See if that helps. |
| Here is one example: 1. Cut the filleted edges. 2. Use _Blend command to "fillet" the edge curves at centre line (check Continuity=Tangency). 3. Use _Sweep2 command to fillet the gap. Use cutted edges as rails, blended curves as cross sections and check the surface edges tangency. Terho
__________________ Only shared knowledge can grow. |
| Tapered chine width | Nojjan | Boat Design | 18 | 08-06-2007 05:24 AM |
| How to fillet corner of two intersecting pieces | Grant Nelson | Software | 1 | 09-13-2006 03:39 AM |
| mold fillet material | Dark57 | Fiberglass and Composite Boat Building | 9 | 09-11-2006 01:27 PM |
| How to Fillet Corners? | S Hondros | Boat Design | 8 | 08-29-2006 03:28 AM |
| Alternative fillet materials? | Ward | Boatbuilding | 16 | 09-03-2004 09:40 PM |
