Old 11-13-2003, 11:48 PM
Willallison's Avatar
Rep: 2283 Posts: 3,468
Surface thickness - in Rhino
Ok - onto my next Rhino problem - you guys should work on commission!
How do you go about making a surface a given thickness? Say I import a hull model (incidentally is the best way to this as IGES surfaces?) anyway - so the sides are say 50mm thick and the bottom is 75mm. Then I model the cabin - sides say 50mm thick again...
What to do?
Will
Imaginocean Yacht Design
www.imaginocean.net
Old 11-13-2003, 11:58 PM
BrettM's Avatar
BrettM BrettM is offline
Rep: 16 Posts: 204
Um.. Offset, Extrude Solid...You don't always need to model both sides. Most stuff normally only come off one side. Your not having 50mm cabin sides on 01 are you?
Old 11-14-2003, 07:26 AM
SailDesign's Avatar
Old Phart! Stay upwind..
Rep: 637 Posts: 1,720
Will,
What Brett said, essentially, although I'm not sure why he is extruding stuff.... ;-P
Just offset the hull, trim back to centreline if needed, and join it all up with a little skinny surface at the sheer. Deckhouse similar.
Unless you _need_ the inner surface, I usually delete it after trimming anything against it that needs it (bad grammar, good practice )
Steve
Old 11-14-2003, 05:23 PM
BrettM's Avatar
Rep: 16 Posts: 204
I mentioned extrude for things like plates with a hole in them. You can then fillet the edges easily if required. Perhaps not so applicable to a cabin top but easily applied to a bulkhead.
Brett
Old 11-18-2003, 06:39 PM
Thanks guys - I'll get back to you in a couple of years when I've nearly got the hang of all this!!
Will
www.imaginocean.net
Old 11-30-2003, 01:58 PM
Polarity Polarity is offline
Rep: 148 Posts: 480
Hi Will
A variation on a theme - if applicable - is to use "offset surface" and the "solid" option (type "s" when it prompts for thickness). That would create a bowl from half a sphere in one go for example.
Paul
Old 11-30-2003, 05:34 PM
hmm - seems to make sense - thanks Paul.....
I'm really struggling with Rhino at the moment. I've done the tutorials a couple of times, but just can't seem to get the hang of it. I have a new computer arriving at the end of the week - hopefully it will be smart enough to help me out!!
Will
www.imaginocean.net
iges trimmed surface problem in maxsurf hasicktear Software 16 02-13-2006 12:25 PM
Rhino - calculating the surface Maciej Software 7 06-07-2005 02:01 AM
Building a heat exchanger into the hull djackson99 Powerboats 42 03-21-2005 03:15 PM
Use Rhino to create surface between stations? ivansalasj Software 9 01-18-2005 05:08 AM
hull surface at rhino gunther prien Software 1 08-03-2004 11:32 AM
