Old 02-11-2009, 10:11 AM
Multi600 Multi600 is offline
Rep: 10 Posts: 8
surface edge problem
Hi
I am trying to create chine plates as individual surfaces in Rhino from an imported 3d lines plan. I have duplicated the each chine line to use one for the upper edge of one plate and the other for lower edge of the adjacent plate. I an using the edge surface command and the surface produced looks fine when viewed on it's own. The problem is that despite using the same curve to produce the connecting edges there are still gaps between the chine plates.
Thanks
Old 02-12-2009, 03:03 AM
pavel915's Avatar
pavel915 pavel915 is offline
Rep: 154 Posts: 319
you can try surface>surface eidt tools>merge
Md. Al-Amin Pavel
http://www.paveldesign.tk
"A question that sometimes drives me hazy, am i or are the others crazy?"
Albert Einstein
Old 02-12-2009, 03:13 AM
Martijn_vE's Avatar
Martijn_vE Martijn_vE is offline
Marine software developer
Rep: 401 Posts: 252
Could be a rendering problem. Adjust your mesh settings.
Old 02-12-2009, 03:30 AM
Rep: 10 Posts: 8
Pavel915. I have joined the surfaces for the sake of appearance and saved as a different drawing but ideally I wanted to keep the surfaces seperate so I could un-roll the developed plates.
Martijn_vE What settings would you think appropriate to try. I tried a few but no real effect on the edges.
Thanks for the reply's
Old 02-12-2009, 05:16 AM
daiquiri's Avatar
daiquiri daiquiri is offline
Engineering and Design
Rep: 2574 Posts: 2,731
It happens often with other 3D software, like Solidworks or UGS. You'll have to play a little bit with parameters of the sweep function (or whatever function you've used for creating your surface). Try changing the degree of accuracy, conditions of tangency, sweep direction.
efficiency of surface drives and surface piercing propellers David Knight Powerboats 7 09-24-2009 04:10 PM
best leading edge? lunatic Boat Design 3 11-30-2008 10:14 PM
Edge Marine Outlaw Powerboats 1 12-13-2006 04:47 PM
iges trimmed surface problem in maxsurf hasicktear Software 16 02-13-2006 11:25 AM
Surface percing propeller matching problem manunk Props 1 06-21-2005 03:12 PM
