| Class society rules and ISO standards are intended for conventional and well-defined construction techniques and materials. I believe that the class society inspector will want to see a proof of validity for every unconventional solution he notices during the construction. Another good reason to get a consultancy regarding that part from a NA or an engineer, possibly at the early design stage. |
Particularly in DNV, there is a requirement of min 2400g/m2 of glass for outer skin of bottom; that's too much.
__________________ http://albatrossdesign.livejournal.com |
I personally don't have a problem with this at all..especially considering its much lower Modulus compared to ally, and as noted by D, abrasion resistance too. |
I'm interested in how designers use FEA in composite design, I can see some nasty traps. Probably the best approach is to set the material properties similar to composite and treat the model as a isotropic material, identify the stresses and then design the laminate accordingly. Remembering to apply enough FOS for material properties that change through time and use. Expected life time will be a big consideration. Has anyone done serious elastic instability studies with FEM on composite structures?
| Small side question: Is there a program, that you can enter bulkhead shapes at various stations into, then play with the rocker and BWL on to see what different effects happen? Maybe generate Cp and Froude or Gerr type numbers? I have been doing this manually, on paper. It's very time consuming to try various shapes. It would be nice to pick and drag the major axis of elliptical shapes and easily come up with "fore and aft CB" in the case of rocker. Stuff like that... dragging ellipses around and finding volumes they displace as well as summations of their buoyancies and effects on COG/CB. Any software out to make that more simple to play with? |
Once I have finished the analysis, i wait until i get the confirmed results back from the coupon tests to verify what the E, v, and tensile modulus is, and then do my final reviews. I only ever use real world, coupon tested values, never theoretical, nor, do I use individual layers, since it is impossible to verify, even experimentally. Quote:
It is just hydrostatic head, ie depth, and then the scantlings are determined by the length and the breadth of the structural members on the WTB. |
I am wondering if I take my well designed hull form and then modify it (by changing deepest point of rocker, etc...), what will the effects on static trim and dynamic speed be? I'd like to enter all my stations in and then grab onto the rocker line (as an elliptical section) and pull the point of max draft around on the computer, as well as pull the total draft around. Basically, a tool to speed up the trial and error process of mating a hull's rocker with the weight distribution, but making sure you don't blow the performance of the hull. I'd also like the software to allow me to change the BWL at the various stations defining the shape at the waterplane (fineness of entry, etc...) and come back to me with the effects on static stability and dynamic hull speed once again. I've been doing this stuff by hand by approximating shapes as conic sections or ellipses (since on a long, thin multihull, that seems to be the way to go) and trying various values by trial and error on paper. I am assuming there has to be a tool written for this iterative process to save me the time of doing it all on paper. The idea would just be to grab the line that represents, say, the BWL and drag it to change its shape, or change the widths of the stations individually to change its shape, thus altering the static stability, Cp and dynamic speed estimates. I hope that makes sense. I obviously do not know all of the terminology. I am not a trained NA, obviously, just a guy who understands some of the basics and is exercising old, unused math and physics muscles. Looking for the software to make it a little easier now that I've been doing it on paper. |
All you need is a simple hydrostatic stability software program. If you haven't got one, or can't afford one, then sadly, it is paper and pencil with your calculator and hours of endless calculations to produce curves of LCB, MCT, LCF etc etc at varying drafts ![]() |
| Really? I thought Cp meant something on 10:1 L/B hulls. Seems everything I read tells me that. Anyway, thanks. I'll try to find some hydrostatic stability software that runs natively on OSX (.5.8) I do imagine I can afford the software, given I'm in the middle of building a 45 LWL x 25' Beam catamaran out of Corecell and epoxy... ha ha ha This is a project to design and build the tender. ![]() |
#25
). Freeship seems to be the popular one here for small boat design. |
#26
What are you doing? Running the Linux version and adjusting it to run on OSX? Failing that, I guess I'm going to have to go to a fast WiFi hotspot and download myself a windows emulator. I suppose freeship looks good and I'll try modeling the hull in that. Thank you! |
#27
| Ooops, sorry Cat, I missed the OSX bit. My life has enough complications without stepping to the darkside to spite Mr Gates |
#28
Regards APP |
#29
If you download any of the free Class rules now available, it is a simple case of reading the rule, measuring the dimensions from your GA and using a hand calculator with pencil and paper. If you can do simple arithmetic and algebra, it is not difficult, just a bit time consuming. Far better than relying on a text book not suited for such vessels too. |
#30
Of course, your spreadsheet computed boat wont loose its keel. But it will be more expensive to built and/or less performing than boats with FEA study. Rather hard to sell... |
| Laminate design and analysis software | Parkerconv | Software | 3 | 04-04-2011 12:53 PM |
| Motion analysis software | catsketcher | Software | 5 | 04-22-2010 08:36 AM |
| structural analysis of frp yacths | amateur mariner | Software | 6 | 02-02-2010 10:10 AM |
| Marine Structural Analysis Software | Casper | Software | 7 | 11-27-2008 09:35 AM |
| Analysis software | concrete canoe | Boat Design | 2 | 02-01-2005 08:50 PM |
