Old 04-13-2004, 05:48 AM
fede fede is offline
Rep: 34 Posts: 281
strakes in maxsurf
Which is the best way to apply strakes to a hull in maxsurf?
Old 04-13-2004, 08:09 AM
Rep: 206 Posts: 391
I recommend doing each strake as a single surface with linear (order 2) flexibility transversely. Intersect them with the hull, leaving sufficient overlap inside the hull, and then used trimming to trim away the excess strake and the piece of hull surface inside the strake.
Make sure that the strake closes properly at each end, either by using a separate surface (e.g. a transom) for closure, or by making sure that the strake feathers out completely.
Andrew Mason
Formsys
http://www.formsys.com
Maxsurf Academic
I Want to get help in Maxsurf. zzt9876 Software 4 02-01-2005 07:48 PM
Q. Lines-planes form AutoCAD to Maxsurf ? cmcguinness Software 0 12-06-2004 04:02 PM
AC yacht modelling accurately on Maxsurf?? ac4ever70 Software 2 11-24-2003 08:48 AM
