  #106
Old 11-01-2009, 12:45 PM
yipster's Avatar
yipster yipster is offline
Rep: 1027 Posts: 3,268
thanks for the explanation on those corners, i understand now, in freeship open the bow and close it like a stern
you can check devellopability as these ends best dont have to much twist. lewis knows after building six it was rite?
as for the million other parts of the design i ssumed you were refering to resistance, stabilty, velocity etc
construction and how the "corners" (or how do we call them?) can be any way you like i guess, good luck !
ps. a florida roofer once told me nailing X wise was more hurricane proof and expensive ;-)
  #107
Old 11-01-2009, 03:25 PM
frank smith frank smith is offline
Rep: 154 Posts: 670
Originally Posted by thudpucker View Post
"..those corners.."
As a kid I worked as a Roofer. On new construction, the "Sheets" are laid out on a big table somewhere for all the contractors to use in making sure they are doing their part correctly.
With a good Architect, almost every nail is located in those "Sheets"
That's what I meant by a 'Million other parts' to the design (sheets).
Just think how complex something with twin engines, several fuel tanks, creature comfort plumbing, wiring, etc would be.
I look at that like making a Lace blanket. Too much detail work for a hacker like me.
As a builder for 35 years I can tell you that it would be luck if the architect had the door in the right place .
sorry Apex ,looks like another hijack
  #108
Old 11-01-2009, 03:37 PM
M-Sasha
Originally Posted by lewisboats View Post
GOD I'M HAVING FUN WITH THIS THREAD....!!!!!!!!!!!!!!!!!!!!!!!!!
(makes a 7 day work week of night shifts worth it.... being able to play at something that is FUN)
OK...so I need a life....I just can't find one that suits my schedule!
Long ago, but so it started!
and got a positive echo
Originally Posted by apex1 View Post
But as mentioned above, as soon as we have managed to produce some sort of "buildable" shape, I would like to leave the further step to next step, tutorial to the better skilled part of our audience.
And thanks for the contribution! Exactly that way I had in mind when starting this thread, to supplement with others advice!
Regards
Richard
then
Merde
the first post with negative touch.
now on his own thread
Nasty!
I simply don't subscribe to the way the thread is running. If you have a useful comment to make please join in ...if not...shoo fly!
I made my points! If you would take the time to re-read the whole thread and see...they were dismissed when it came down to brass tacks. I have since endured a number of distasteful PMs from the author of that thread and I have decided to try and rectify things with a serious thread aimed at what I thought the original one was going to do. So...again...I say...If you wish to contribute with something substantial and related to the thread...by all means have at it...otherwise take the nasty comments back to the other (what has become) mud slinging thread. Deselect all!
Do you really think that I would be allowed THAT much leeway in THAT thread...to post like I am doing now? Me thinks I would be accused of hijacking the thread in a most severe way...don't you?! Deselect all
What a sad individual.
Sasha
  #109
Old 11-01-2009, 04:14 PM
apex1
Ahhh ja.
All said already.
Enjoy your Sunday peers (and Vladimir, Frank, and Lewisboaty too of course)
  #110
Old 11-02-2009, 03:28 AM
fcfc fcfc is offline
Rep: 333 Posts: 679
I do not understand all that mess ...
Nobody confuses this software output http://blenderartists.org/forum/showthread.php?t=97202 with automotive engineering. For boats, it is absolutely exactly the same thing.
  #111
Old 11-20-2009, 09:00 AM
Mr Meebles Mr Meebles is offline
Rep: 10 Posts: 6
Gentlemen: enough said about protocols - this is a GREAT thread!
Please, could somebody tell me how to use the "keel/rudder" function to put appendages on adeveloped hull?
I suspect that it is a "layer" function, but I'm still toddling when it comes to uses that...
Any help that the experts can provide will be geatly appreciated
S/F, Phil
  #112
Old 11-20-2009, 09:09 AM
thudpucker's Avatar
thudpucker thudpucker is offline
Rep: 330 Posts: 703
I just wanted to make a sketch drawing of an add-on porch. I wanted to know how many 2X's etc I needed.
I downloaded about four of those 'easy to do' programs.
I wound up doing it with a pencil on a napkin at coffee one morning.
  #113
Old 11-20-2009, 09:32 AM
Fanie's Avatar
Fanie Fanie is offline
Fanie
Rep: 1930 Posts: 4,195
Solid Edge have their 2D cad drawing for free. Unfortunately there isn't an easy to do program that is worth using you can just use and get what you want. It should be doable though. Some of the PCB programs are going that way. It's almost logic to use them, so the learning curve is maybe an hour. Who knows, maybe one day someone other than a melancholy engineeer would write software that works easy.
Regards
Fanie
Water ! Just gimme water !
  #114
Old 11-20-2009, 10:48 AM
Rep: 10 Posts: 6
Can porches sail (in the absence of hurricances)?
  #115
Old 11-20-2009, 10:55 AM
Rep: 154 Posts: 670
That would depend on what you are smoking .
  #116
Old 11-20-2009, 11:01 AM
Rep: 154 Posts: 670
S/F, Phil
You might get help posting this to a Freeships thread . But I am sure it is not to hard ,
Just look around for rudder and keel stuff.
step design question BWD Boat Design 2 05-06-2009 12:04 AM
Twin-Step hull design for CC Outcast Marine Boat Design 1 01-14-2008 11:58 PM
Redesigning a step boat BlueMind Powerboats 9 01-11-2008 12:40 PM
Design Factors to Step The Main Mast. seasaltchap Sailboats 12 06-29-2007 10:25 PM
I'm looking for first step into boat design ale2006 Boat Design 4 04-13-2005 09:11 AM
