| Stability Software For high end stability: Autoships AutoHydro or GHS or ??? Advantages/Dis-Advantages? I need to make a decision. Thanks for the input. |
| I've used GHS, but cannot comment on the other software. Basically, it works quite well (since hydrostatics is what it was designed to do). However, I've noticed that for damaged stability in very extreme conditions, the trim and sinkage iterations become unstable. In other words, I think there is a problem with calculating the free surface in various flooded compartments at 30+ deg heel. However, I still think GHS is good software. By the time you do hydro"static" calculations on a sinking ship, it may be a better use of time to do calculations on how many liferafts you need. -Jon |
| Try Hydromax, I am confident you will find it much better than either GHS or AutoHydro
__________________ Andrew Mason Formsys http://www.formsys.com Maxsurf Academic http://www.formsys.com/academic/maxsurf/ |
| I can only agree with Andrew - I've only used Hydromax but it has never let me down - once you know how to use it properly. |
| Stability software | CGN | Software | 18 | 04-25-2009 05:51 PM |
| basic software for intact/damage stability | John Toner | Software | 13 | 10-20-2007 05:55 AM |
| stability software | Tim_Hastie | Software | 30 | 11-28-2006 12:40 PM |
| Software for submarine Design & stability | Bassoom | Software | 5 | 06-14-2005 10:41 AM |
