Old 09-18-2007, 09:26 AM
tallen tallen is offline
Rep: 10 Posts: 30
Stability calcs from Rhino model
I have a hull I made in Rhino and I want to do some damage stability calculations on the hull. What is the best way to go about doing this? Is there any plugins for rhino, other good software that is friendly with rhino hulls. Is any of this software low cost / free?
Old 09-18-2007, 10:46 AM
CGN CGN is offline
Rep: 138 Posts: 547
For Damage stability the "low cost" ones that i have seen are Hyss.xls and the stability module from NewWavesys (Prosurf line of software) Prosurf is around 2000US and Hyss.xls is 750 euros.
Prosurf stability module can read GHS (??), and Hyss is a little bit more work becouse you need to input the curves that defines your model, but it does the job.
Old 09-18-2007, 10:55 AM
Rep: 10 Posts: 30
How about AutoHydro, or any others that would have a student discount?
Old 09-18-2007, 12:28 PM
yago's Avatar
yago yago is offline
__
Rep: 17 Posts: 118
If you only need it for one boat, you could use the time limited trial version of Rhinomarine, download at www.rhinomarine3d.com
Gerd
__________
www.yago-project.com
Old 09-18-2007, 12:31 PM
Rep: 10 Posts: 30
I thought Rhino Marine only does intact stability and not Damage stability
Old 09-19-2007, 12:00 PM
ABoatGuy ABoatGuy is offline
Member
Rep: 79 Posts: 192
Tallen,
Rhino can write a GF file which can be read by AutoHydro or GHS, both are full stability packages.
Old 10-06-2007, 01:04 AM
Rep: 10 Posts: 30
I was wondering what is the best way to do this calculation by hand if no software is accessible to me. Most methods i have seen rely on using a tangent waterline to the margin line... the problem i have is that my bulkhead deck is parrallel to the waterline and it is flat. So can anyone please help! Need this help urgent.
Old 10-06-2007, 09:36 AM
Member
Rep: 79 Posts: 192
Stability calculations by hand are extremely tedious. You don't want to go there if you can avoid it. That said if you can find a copy of Skenes Elements of Yacht Design, there are fairly detailed instructions in the back. The book is out of print, but libraries often have copies or try Amazon used books.
Phil
Old 10-06-2007, 10:43 AM
Martijn_vE's Avatar
Martijn_vE Martijn_vE is offline
Marine software developer
Rep: 401 Posts: 252
It's back in print, bought one recently.
Old 10-16-2007, 02:09 PM
yachtboy yachtboy is offline
Rep: 10 Posts: 6
Elements Yacht Desing
hi,
Elements of Yacht desing has re print done 2001, so new ones available.
If you need no cost package just for stability you might find
DelftShip usefull. It dose most of work.
But STIX kind of criteria need's something more, I have been working
out own pure calculation system and at near future it's capeable to
calculate 360deg,....
Anyway look at http://www.delftship.net/, just wondering why did not
starting whit hull desing at delftship. Perhaps next time.
joni
http://desing.myjohn.info
ps. if anyone intrested to network, to get projects, to get projects done,
needs company,... welcome to desing.myjohn.info
Phil
Old 10-19-2007, 06:00 AM
terhohalme's Avatar
terhohalme terhohalme is offline
Rep: 478 Posts: 485
Leak stability in RhinoMarine
I put this first to a wrong thread:
Could this be a suitable solution?
First, calculate hydrostatics with a sound hull and pick up displacement and LCB.
Then cut off the leaking compartment of the model and calculate hydrostatics/CG (use previous LCB and displacement). The model trims and heels nicely.
Stability calcs from Rhino model-intact-stability.jpg  Stability calcs from Rhino model-leak-stability.jpg
Old 11-05-2007, 11:18 AM
Magno Magno is offline
Rep: 10 Posts: 4
Cutting a part of the model is valid and is used by some programs for Damaged Stability. But you must also put in mind that, if there is equipment or structural elements inside the compartment that was flooded, the water will not take the place of them. If you do not need more realistic results I think it can be done.
Another thing you can do is put a weight representing the water that entered in the compartment and adjust the water density to consider the presence of solid elements (machinery or structural elements) in the flooded tank.
Fighting Chair Model in CAD or Rhino dannysm213 Software 5 05-11-2010 12:49 PM
stability analysis by maxsurf, rhino , and archimedes! pavel915 Stability 16 08-01-2007 02:06 PM
Scaling a model in Rhino only in one direction (beam) SOYUTA Software 2 11-26-2006 01:45 PM
Assigning Thickness to Rhino Model S Hondros Software 7 07-23-2006 04:12 AM
3D Rhino model and 2D drawings signum Software 2 08-19-2005 06:35 AM
