| Solidworks Hello Folks, I just recently became an Applications Engineer for a Solidworks integrator in Minneapolis. I know not many use Solidworks for hull design, but you may use it for part design. I would like to get some pro/con feedback from anyone in the field using this software on a regular basis. I would be especially interested to hear from those who DO use it for hull design. Thanks, Rick |
| I am not a pro designer but I use it as I don't know yet how to use some other progs. It is kind of tricky, from time to time you have to find a workaround to get things done. For now it is SW2001 and I think it is a bit out of date. I think latest SW will have better features? But indeed you can do almost anything with it. Greetings,
__________________ Daniel Peeters |
| Thanks for the feedback. Current version is 2005 (go figure) |
I can tell you that it is a bit tricky lofting to a point, like the bow of a boat. I'm continually ending up with hollows in the waterlines forward. It seems doing a Surface Loft is better than a Base Loft, but then thickening is a problem since the two surfaces overlap in the corner created at the bow. It is also a bit frustrating trying to loft a deck off of an existing hull, since the sheer is a non planar surface. Ditto the cabin house on top of the deck If you want to add that, then knit house and deck together. Finally, I find it impossible to loft or Sweep a keel foil section that is curved on the leading and trailing edge at the same time (as most high aspect sailing rudders are, and many keels as well). The boat models I did in the 17 foot keelboat discussion are all SW, with PhotoWorks rendering. http://www.boatdesign.net/forums/att...achmentid=1978 |
| You should be aware that there is a major effort in software development for second tier shipyards. See www.nsrp.org. |
| Solidworks for boat design? | Baldur | Software | 10 | 08-19-2005 11:44 AM |
| Solidworks | asathor | Software | 1 | 11-11-2004 10:34 PM |
| SolidWorks | SAQuestor | Software | 0 | 09-22-2004 01:28 PM |
| Using Prochine and Solidworks together. | CTI Performance | Software | 11 | 03-06-2004 04:16 PM |
