Old 05-22-2005, 05:47 PM
Bassoom Bassoom is offline
Rep: 10 Posts: 16
Software for submarine Design & stability
hi everyone :
i'm working on submarine design & simple hydrostatics.
i'v tried to use Autohydro to calculate the hydrostatic data, but it fails to perform the underwater stability .
i need a program to help me with this please .
also,i need a program to help me with submarine design .
i will be very gratefull if any body can help me .
Old 05-23-2005, 03:11 AM
jamac jamac is offline
Rep: 10 Posts: 31
Hi there,
What is it you are tryin to do exactly that Autohydro cannot do?
I would be surprised if there is not something you can make work with it.
Where is it failing?
JA
www.naval-architecture.co.uk
Low cost Naval Architecture and Marine Software
Old 05-23-2005, 12:50 PM
marcusbole marcusbole is offline
Rep: 10 Posts: 3
Hi Bassoom,
You might be interested in taking a look at Paramarine (http://www.grc-ltd.co.uk). It has specific modules for addressing submarine design and stability. Sub stability seems to be quite different from surface ships.
regards,
Marcus.
Old 05-23-2005, 06:12 PM
Rep: 10 Posts: 16
hi eveybody:
the proplem that Autohydo can't deal with the submarine when it's under the water, it was only designed for floating structures.
thanks marcusbole, paramarine is good but i think it is unreachable for me.
do you suggest any another program (simple, reachable & free)
Old 05-23-2005, 06:46 PM
Rep: 10 Posts: 31
Hi there,
Marcus is absolutely correct. Paramarine is very very good at submarine design and stability and their website has a lot of material to support this but of course is expensive.
Let us know exactly what it is you are trying to do. If you only need cross curves (movements in TCB for angles of inclination) for a submerged body then my wee application should be able to handle this. It doesn't cost much and a basic version is free. Even if this is a problem and you are a hobby user or its Uni/Research then drop me a private line and I can send you a free unlock code.
HTH
JA
Old 06-14-2005, 10:41 AM
rxcomposite's Avatar
rxcomposite rxcomposite is offline
Rep: 614 Posts: 720
Submarine
Hello to all,
Hi. I too is working on a submarine project. It is still in the conceptual stage. Its going to be for commercial application, underwater sightseeing, depth of about 25 to 50 feet. Lots of viewing glass.
Im about to buy SNAME's Submersible Vehicle Systems Design.
I would appreciate any software design, website, or good book that i can be led into.
Thanks in advance.
I need a Lead Naval Architect or assigned Project Enginner ESG Services & Employment 12 11-06-2004 10:29 AM
