| sizzurp "..My question is just if there's any software to calculate wave patterns.." There are plenty about (for the type you are looking for), but are they accurate, is a totally different matter. That comes down to the how's and why's, not the pretty pictures. There has also been a lot of work done by the MCA in the UK on wash and also by Whittaker et al, Dand et al, and Kofoed-Hansen et al. You may find the attached of interest, not widely obtained. These are generally more for the "mathematically" minded that do research in that field. |
| For now, it don't have to be very accurate. I don't need to know the exact height of waves, just want to compare some hulls. It's just a little research before I start. And thanks for the recommendations. |
| sizzurp I'm confused. If you're not worried about the accuracy, what difference does it make which software you use? Without any kind of validation, the answers you're going to get, as a sensitivity analysis, will be no better than any other software, and just as inaccurate as each other. It is somewhat akin to using a saw, to hammer in a nail...you can do it, but not very well...and not every nail consistently, nor easily. Just questioning your rationale in using a method that is not consistently accurate for all applications (non of them are), for comparisons, doesn't make sense. From a research, phd, perspective, but from a layman's perspective, it is fine... |
| I meant: I don't need to know (for example) the exact wave height on a mm.. I just want an easy in use software for my first calculations. And not a program were I need to know every little detail for the input. |
| Michlet will allow you to quickly compare simple hullforms like a Wigley or a parabolic strut. You can also see (far-field) wave patterns of multihulls with up to five demihulls. See the example section in the documentation of simple cases for catamarans and SWATH, trimarans, tetrahulls, SLICE, and pentamarans. |
| And a little more reading material for you... I know you aren't specifically interested in the resistance aspects, but check out some of the high form factors in the paper by Molland et al. 1.47 for a catamaran! |
| and to hear another why not this extra book by Odd M Faltinsen Hydrodynamics of high-speed marine vehicles |
| The Hullspeed module in the Maxsurf suite of software uses a slender body method to calculate wake waves and resistance for slender hull forms. http://www.formsys.com/maxsurf/msproducts/hullspeed The attached picture gives an example of its output. There are more technical details in the Hullspeed user manual in the download section of the FormSys web site. |
| Fluctuating LWL and wave patterns. | Omeron | Boat Design | 7 | 03-06-2008 12:11 PM |
| Non slip patterns in Gel | spegtek | Materials | 1 | 09-23-2006 09:11 AM |
| Free patterns? Is there anybody who knows? | millos_bgd | Boat Design | 6 | 04-08-2005 06:24 AM |
| Hatch Patterns | Willallison | Software | 2 | 01-29-2004 10:05 PM |
| flatten patterns | Boat Design | 4 | 12-10-2001 07:30 PM | |
