Old 11-14-2010, 05:37 AM
s.Angel s.Angel is offline
Rep: 10 Posts: 8
software: Autoship vs Rhino vs Maxsurf?
I Have A Question.whats The Diffrence Between Autoship And Rhino And Maxsurf? I Want To Design A Boat For Toorbo With Waterjet. If You Know Any Software That Can Help Me Please Say To Me.
Do You Know Any Thing About Fastship Software.
Old 11-14-2010, 11:57 PM
bbsboat bbsboat is offline
Rep: -10 Posts: 39
I use maxsurf and rhino, MAXSURF easy to build a hull ,and easy to use hydromax to caculate hydrostabilitys. Rhino is good at build the superstature. and with rhinomarine(a plug of rhino,)you can also do some caculat.
http://www.theboatpictures.com boat pictures
Old 11-15-2010, 07:26 AM
ACuttle's Avatar
ACuttle ACuttle is offline
Marine Design Engineer
Rep: 40 Posts: 85
I haven't used Autoship so I cannot comment there, for the other two the main differences are:
Maxsurf is piece of marine design software engineering specifically for the production of NURBS hull models along with some of the associated calculations. It gives a strong toolset for the fairing and modeling of hulls.
Rhino is a general 3D modeling package that is very strong at modelling complex forms but isn't designed specifically for marine-applications. It is very good at reworking surfaces, trimming and extending sectios (which Maxsurf is very bad at). Works in conjuction with Workshop to produce frame sections, stringers and plating.
Proffesionally I use both, Maxsurf for the creation of hull-form and Rhino to modify and edit the form to a build state. There are marine plugins for Rhino but you'd be looking at doubling (roughly) the original price of the software (apx 5000-6000 GBP).
It depends on your budget and forward planning the way you want to take things. Both are very powerful, if I had to have one I'd take Rhino for the ability to model just about any form but I'd be left having to do alot of stability etc. work by hand.
-Drew
Old 11-17-2010, 02:15 PM
Joe Petrich Joe Petrich is offline
Designer
Rep: 141 Posts: 158
I used to use Autoship but switched to Rhino + Orca3d. Autoship is good but you can do a lot more for less money with Rhino and Orca3d. I have used a demo version of Maxsurf only so I can't really comment on it, although I have heard good things about it. Rhino creates very fair hulls if used correctly. I produce 150-250 ft yacht hulls and superstructures with it and have had no problems. I wish I could show you the hulls but our work is proprietary. All three of these programs produce good results.
Old 11-18-2010, 02:32 AM
fcfc fcfc is offline
Rep: 359 Posts: 709
Maxsurf has versions with a relatively low entry price, but as soon as you add Hydromax and Workshop, prices go up very quickly.
I do not know how someone can design a boat in maxsurf without hydromax.
Maxsurf/workshop V's Autoship alidesigner Software 0 11-27-2009 09:11 PM
Maxsurf or Autoship deej Software 17 05-26-2009 02:55 AM
autoship files to maxsurf yacht picasso Software 8 07-09-2007 10:09 AM
autoship to maxsurf hello Software 4 08-02-2004 01:17 AM
Maxsurf VS Autoship christos Software 3 02-19-2002 10:51 AM
