Old 09-01-2008, 01:21 AM
ovidiuse ovidiuse is offline
ONESoft Solution-NC soft
Rep: 10 Posts: 12
SoftONE CNC application - a new DXF to NC application!
SoftONE-CNC application generates NC-code from TRIBON “gen” files and AUTOCAD “dxf” files for computer controlled burning machines with plasma arc cutting, gas cutting, laser cutting and other manufacturing applications.
SoftONE-CNC is designed to run in Windows 2000/XP.
The graphical user interface (GUI) makes it easy to learn. A new user can produce reliable NC-code within the first ten minutes of using SoftONE-CNC.
SoftONE-CNC offers the following main features:
- Converts TRIBON “gen” CAD files to reliable CNC-code for 2 axis cutting machine.
- Converts CAD “dxf” files to reliable CNC-code for 2 axis cutting machine
- Conversion times including user selection is fast
- Automatic error correction features
- Automatic path generation.
- Manipulation of “V” bevel codes (from tribon files)
- Easy to learn graphical user interface
SoftONE–CNC features:
- Works like a graphical NC postprocessor for Tribon users
- Read and convert to NC codes bevel instruction from Tribon “.gen” files
- Read and convert to NC codes Autocad or other software which can export DXF files.
- Easy to change bevel codes.
- Separating process entity by colors
- Export nesting plates to Autocad DXF performing different layers and colors for each process.
- All duplicate entities, i.e. identical lines or arcs, are automatically deleted.
- Allows the user to set the lead-in and lead-out length independently. You can create NC-code with no leads, lead-ins only or lead-ins and lead-outs.
- Optimize the complete path automatically from the DXF file for reducing the cutting time process. - Simulation on the screen of all processes
- Mark using rapid travel speed.
- Generate marking or cutting path only.
- Allow the user to set-up the input filters, extension of the output NC files, motion settings as well as bevel settings of the resulted file.
- Works with both standards :ESSI or G-codes with or without bevel
SoftONE CNC application - a new DXF to NC application! ovidiuse Software 7 03-28-2012 02:50 AM
Resin Application weissmarine Fiberglass and Composite Boat Building 6 08-02-2008 09:50 PM
What's the best glass to use for my application? mongo75 Fiberglass and Composite Boat Building 6 09-14-2007 02:22 PM
Antifouling application alpamis34 Boatbuilding 6 01-27-2007 10:12 AM
New boat application Tom_McGuinness Boat Design 0 08-08-2004 11:14 PM
