| SoftONE CNC application - a new DXF to NC application! SoftONE-CNC application generates NC-code from TRIBON “gen” files and AUTOCAD “dxf” files for computer controlled burning machines with plasma arc cutting, gas cutting, laser cutting and other manufacturing applications. SoftONE-CNC is designed to run in Windows 2000/XP. The graphical user interface (GUI) makes it easy to learn. A new user can produce reliable NC-code within the first ten minutes of using SoftONE-CNC. SoftONE-CNC offers the following main features: - Converts TRIBON “gen” CAD files to reliable CNC-code for 2 axis cutting machine. - Converts CAD “dxf” files to reliable CNC-code for 2 axis cutting machine - Conversion times including user selection is fast - Automatic error correction features - Automatic path generation. - Manipulation of “V” bevel codes (from tribon files) - Easy to learn graphical user interface SoftONE–CNC features: - Works like a graphical NC postprocessor for Tribon users - Read and convert to NC codes bevel instruction from Tribon “.gen” files - Read and convert to NC codes Autocad or other software which can export DXF files. - Easy to change bevel codes. - Separating process entity by colors - Export nesting plates to Autocad DXF performing different layers and colors for each process. - All duplicate entities, i.e. identical lines or arcs, are automatically deleted. - Allows the user to set the lead-in and lead-out length independently. You can create NC-code with no leads, lead-ins only or lead-ins and lead-outs. - Optimize the complete path automatically from the DXF file for reducing the cutting time process. - Simulation on the screen of all processes - Mark using rapid travel speed. - Generate marking or cutting path only. - Allow the user to set-up the input filters, extension of the output NC files, motion settings as well as bevel settings of the resulted file. - Works with both standards :ESSI or G-codes with or without bevel |
| More informations and also free NC software at: http://www.onesoft.ro
__________________ ONESoft - http://www.onesoft.ro |
| SoftONE-CNC V3 Version 3 new features : - NC code analyzing (ESSI and G-Code) and "step by step" simulation through "Back generation" of NC code function - NC code viewer and CNC processes simulation; - Converts NC code back to DXF files via back plotting functions; - Converts NC files from ESSI to G-Code and G-Code to ESSI according to users customized SoftONE postprocessors. More info and description: http://www.onesoft.ro/download
| Version 3.1 Addins: - lead in/out separate enable/disable features; - Kerf calculation function for NC and DXF files; - DXF Export addins: add "path" and "plate" layers;
| SoftONE-CNC V4 SoftONE-CNC V4 new features: 1) New GUI : Microsoft Office style user interface based on the latest .NET Technology. 2) New Standard toolbars, Status Bars, Tree view - New info bar window: nesting info and production info; - New status bar - X/Y tool coordinates shown; - New simulation toolbar. - New CNC toolbar and CNC code list view - new Parts information in Tree View: pos, thickness, block, part area 3) Improved zoom and pan functionality; 4) Nesting edit functions and menu; - Automatic position numbering - Change Part Production info: Part name, position numbers, thickness - Interactive change the lead_in/out angle. - Interactive change leads length. - Delete lead - Delete Part 5) New SoftONE nesting save format (NCE) 6) New customizable Nesting Production Sketch For more information, visit: http://www.onesoft.ro Download SoftONE-CNC V4 Description ![]()
| Resin Application | weissmarine | Fiberglass and Composite Boat Building | 6 | 08-02-2008 10:50 PM |
| What's the best glass to use for my application? | mongo75 | Fiberglass and Composite Boat Building | 6 | 09-14-2007 03:22 PM |
| Antifouling application | alpamis34 | Boatbuilding | 6 | 01-27-2007 11:12 AM |
| Fiberglass Application Engineer | William Weaver | Services & Employment | 0 | 04-06-2005 10:20 AM |
| New boat application | Tom_McGuinness | Boat Design | 0 | 08-09-2004 12:14 AM |
