Old 01-28-2011, 02:59 AM
ovidiuse ovidiuse is offline
ONESoft Solution-NC soft
Rep: 10 Posts: 12
SoftONE-CNC
SoftONE-CNC generates NC-code from TRIBON (Aveva Marine) “gen” files and AUTOCAD “dxf” files for computer controlled burning machines with plasma arc cutting, gas cutting, laser cutting and other manufacturing applications.
SoftONE-CNC is designed to run in Windows 2000/XP.
The graphical user interface (GUI) makes it easy to learn. A new user can produce reliable NC-code within the first ten minutes of using SoftONE-CNC.
SoftONE-CNC offers the following main features:
- Converts TRIBON “gen” CAD files to reliable NC-code for 2 axis cutting machine from Tribon Nesting and Panel Line Control modules;
- Converts CAD “dxf” files to reliable NC-code for 2 axis cutting machine from Autocad and other CAD systems;
- Converts NC codes from ESSI standard to G-Code standard and vice versa via back plotting function;
- Converts NC codes back to DXF files via back plotting function
- Back plotting of NC code function (NC Viewer);
- Kerf tool compensation NC code calculation function
- Automatic error correction features;
- Automatic path generation;
- Manipulation of “V” bevel codes (from tribon files) ;
- Easy to learn graphical user interface;
More information on: http://www.onesoft.ro
Ovidiu
ONESoft - http://www.onesoft.ro
SoftONE CNC application - a new DXF to NC application! ovidiuse Software 7 03-28-2012 02:50 AM
cnc router cut or cnc plasma cut which one to use gary1 Metal Boat Building 25 01-29-2012 05:46 AM
SoftONE CNC application - a new DXF to NC application! ovidiuse Software 0 09-01-2008 01:21 AM
cnc hareb Boatbuilding 4 04-05-2006 09:09 PM
Cnc? Gades Software 12 03-17-2004 12:39 AM
