Old 10-27-2008, 02:03 AM
lazeyjack
Originally Posted by bhnautika View Post
Sean I like the wake images should make great bumps , you mentioned Photoshop in one of the posts, I believe its one of the most important steps as you can add detail that would be impossible to model and render effectively, especially spray and foam. The first image of the original scene I added a wave and a separate surface at the crest to give a contrasting white edge. Second image I photo shopped some spray and foam along the edges and on the waves in the wake.
are you joking, I mean you fergot to stick feein' ports into that toot boot
Old 10-27-2008, 06:45 PM
Sean Herron's Avatar
Sean Herron Sean Herron is offline
Rep: 405 Posts: 1,532
Crest Falls - Ouch...
Hello...
Saran wrap scan to heightfield - bent and sheared - then a twist on a rail and spine...
Geezus... - original was a huge file - trimmed it - just bend straight - or 1D transform - or copy and paste a few - 3DM should give some clues...
Lazey - thanks for the offer...
I think scatter fields can do the foam on the break fall...
Again - thanks Lazey - Bknot - other...
Lazey see http://www.boatdesign.net/gallery/sh...89/ppuser/3673 - have yet to get to freeing ports or other...
cheers folks...
Do you guys have Bongo for Rhino...
SH.
Simple Wave Models In Rhino...-crest-fall-02-treefrog.jpg  Simple Wave Models In Rhino...-crest-fall-02-inherent.jpg
Old 11-04-2008, 11:35 AM
zeroname's Avatar
zeroname zeroname is offline
Naval Architect
Rep: 90 Posts: 262
hy.. i need a simple answer as i dont have much idea about engine.
i am going to measure power and resistance using hullspeed.. i need to put engine efficiency... my question is what is the range of engine efficency i will put? i am doing for small container ship of 74 m .. speed will be 11-14 knots
thanks
Old 11-04-2008, 10:03 PM
Computer says no...
Hello...
You are best to post same elsewhere or to Email 'Formation Design Systems' - or review the manual and fart about...
SH.
Old 11-05-2008, 07:21 AM
zeroname's Avatar
Naval Architect
Rep: 90 Posts: 262
i think here is much expert who use hullspeed and can give me the simple answer...
Old 12-05-2008, 11:23 PM
zeroname's Avatar
Naval Architect
Rep: 90 Posts: 262
need some advice
hy..
i have attach a 3d model done in rhino.. i am not happy with thewave .. canu tell me how i can make more realistic the wave by rendering... i used vray fo it..
does flamingo has advance feature for making good wave render?
Old 12-07-2008, 01:10 AM
bhnautika bhnautika is offline
Rep: 547 Posts: 540
Zeroname by what method did you create the waves? I start with a flat-water surface, which I make a glass like surface with a green tint with bump map. I then put another surface under it, which has a coloured surface. The top surface can be generated by either Sean’s method or by direct manipulation of the surfaces it’s self. I find this method gives me a clear top but stronger colour underneath. The renders were done in flamingo.
Simple Wave Models In Rhino...-wave.jpg  Simple Wave Models In Rhino...-waveandshark.jpg
Old 12-07-2008, 01:56 AM
zeroname's Avatar
Naval Architect
Rep: 90 Posts: 262
i used hullspeed to calculate the resistance and then get the corresponding wave shape at a particular speed ( it was 11knts) .. i just import the surface to rhino and used bump map in v-ray ..
is flamingo better than vray or same ?
Old 12-07-2008, 04:48 PM
Rep: 547 Posts: 540
Zeroname how did you export/import the wave field into rhino from hullspeed as I think you have scaling issues. It appears the wave heights are too large. I think in this case it’s the way you assign materials to surfaces more than the renderer you use.
  #25
Old 01-06-2009, 04:30 AM
zeroname's Avatar
Naval Architect
Rep: 90 Posts: 262
i used to calculate the resistance and power for speed 11 knots.. and hullspeed gives me corresponding wave surface.. then export it as .dxf and import it in rhino.. just make an mirror and used V-ray to render..
  #26
Old 01-14-2009, 04:07 PM
ROO ROO is offline
Rep: 10 Posts: 31
Sean,
bloody brilliant .
bhnautik,
I'm a bit worried about Toot Toot the Tug Boat, did it get pooped by that wave.
  #27
Old 01-14-2009, 06:25 PM
What...
Hello...
I do not like being called brilliant - keep that bit a bit hush - I do not want the responsibility that is attached to same - besides - I am a really a dumb hill Billy poke to be doing this stuff in the first place...
Tell you what is brilliant - Carbonite Online backup - unlimited for about 50 bucks a year - if I had done same - I would not now be without a year and a half of work or 'mental meandering' - ****...
Any way thanks - I get bored quickly - ADS...
Thank God for this site - need to start pulling my files out from same and rebuilding - when Bill Gates dies - I will have to clap my hands with glee...
If he does not die soon - I may sell my now worthless Ford and invest in a rocket launcher...
Thanks again...
It's all 'scanner play'...
SH.
  #28
Old 01-14-2009, 06:26 PM
Rep: 547 Posts: 540
Roo toot rode it out too the end but the duck was not so lucky!
  #29
Old 01-14-2009, 06:46 PM
Burp...
Hello...
A tip to 'Jeff' or the site owner - glad for same - had a ballistic crash - all backups same - glad to have uploaded my 'crap' to this site where I can retrieve same at some level of completion...
Thank you...
SH.
  #30
Old 01-14-2009, 07:30 PM
ROO ROO is offline
Rep: 10 Posts: 31
bhnautika
Glad to here toot made it through, I do like a happy ending. Will you please convey my condolences to duckies family, I quess you could say, ducky has had his last quack.
2D Rhino to Autocad export and rhino sectioning fede Software 13 10-18-2009 02:55 AM
3D Boat Models David Cutright Open Discussion: All Things Boats & Boating 2 03-24-2008 12:28 PM
3D models for download? Guest Software 3 07-24-2004 01:21 PM
Build Models rjmac Services & Employment 2 02-25-2004 04:13 AM
3d boat models Software 5 12-02-2002 12:45 AM
