| Side Ballast Tank Forming Problem In HYDROMAX :( Salutations... I want to form a side ballast tank in my tanker. But inner hull boundary is really complex surface.. I applied all of process that explained in hydromax manual but i could not do it successfully. Please help me about this problem ![]() |
| I'm sending the maxsurf file.. |
| I have attached maxsurf and hydromax file with little bit of modification. have a look |
| Thank you very much.. Your advice was really useful. Now, tank plan has changed and double bottom ballast tanks has joined to side ballast tanks. I have to model them in a single piece now.. If i use "Linked tank " modelling way in Hydromax, can i solve this problem? Is this method useful for efficient tank calibrations? Thanks.. |
| Yup. Linked tank let you create tank with complicated boundary. you can counter check your tank by generating volume table. |
| problem with hydromax | mehdiaityoussef | Software | 3 | 05-06-2011 03:38 PM |
| create a trapezoidal tank in hydromax | naserrishehri | Software | 0 | 12-02-2010 02:21 AM |
| Problem with Hydromax (MAXSURF) | Sarinha | Software | 2 | 09-27-2010 02:32 AM |
| have a problem of hydromax | chaser | Software | 2 | 07-18-2009 10:53 AM |
| External Tank definition problem in hydromax | ilgazcan | Software | 4 | 12-06-2008 09:18 AM |
